Old 06-23-2006, 03:33 PM
psyko_tek psyko_tek is offline
tranny fluid in radiator
Hi, I'm new here
recently been haveing low fluid in radiator, thought I found a leak in the hoses going to the tranny.
replaced them this am, and the radiator seems to have tranny fluid in it
how screwed am I?
is this just a radiator problem or do I have a rad/ tranny problem?
don't want to spend a alot on this van , gonna junk it soon as I finish getting my '73 road runner rebuilt
Old 06-23-2006, 04:22 PM
Bernard Feltzer Bernard Feltzer is offline
Re: tranny fluid in radiator
Are you retarded?
The two little hoses going to transmission are supposed to have tranny fluid in them.
The two big hoses going to the engine are supposed to have radiator fluid in them.
I think you are screwed up.
Old 06-23-2006, 05:16 PM
Buzzkill101 Buzzkill101 is offline
Dude put the hose back on and if you should have a leak I would say take it to a garage. I will not bash you but before you go tearing into anything you should get a haynes manual and read it. They do have automotive classes that you can take to educate yourself. There is absolutely no way you can get tranny fluid into your radiator. You probably took off a tranny cooling line to your transmission radiator. That is not the same as your engine coolant and radiator system. If you are losing water that is normal as long as it's like every 3000 miles and such. If it's everyday then you are losing it somewhere and should have your system pressure tested. you may have a leaky hose, radiator or faulty cap. You will lose water through evaporation. Make sure you are running 50% water/coolant mix. You can buy it premixed at walmart ready to go.
If you still have problems let us know.
Old 06-23-2006, 05:25 PM
Originally Posted by Bernard Feltzer
Are you retarded?
no dude I have tranny fluid in my radiator, sorry didn't make that plain,
Old 06-23-2006, 10:59 PM
AwPhuch AwPhuch is offline
Banned
http://www.automotiveforums.com/vbul...d.php?t=575510
Been there done that....
Seems like the tranny cooler tube INSIDE the radiator was leaking (only under pressure, thus tranny fluid filling radiator, and not leaking INTO the tranny (which would kill it instantly!))
You will have to replace the radiator...there is no two ways about it
We are in Houston and managed to get a $140 one
P.S. DONT PUT DEX-III IN IT! (I just found this!)
http://www.allpar.com/ed/tips/trans.html
http://www.allpar.com/fix/trans.html
Brian
AwPhuch
