Old 06-23-2006, 10:55 AM
87camarocoupe 87camarocoupe is offline
Engine swap
i was wondering if it is a big job to swap in a carburated 305 into a 2.8 car.
And what parts that i would have to change, motor mounts, driveshaft?
Old 06-23-2006, 11:12 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Engine swap
Yeah, doing a motor swap is usually a pretty big job and it'll probably be pretty expensive. A lot of people that start them do not finish or they have lots of bugs to work out after they get the engine in.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-23-2006, 11:44 AM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Re: Engine swap
engine, tranny, rear end most likely for limited slip which you'll want, wiring, gauges, motor mounts, cross member, and some other little things. The drive shaft will however be usable.
Old 06-23-2006, 12:27 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Re: Engine swap
Why are you choosing the 305? stuck because of price? Or because it's easier to swap than an LT/LS1?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 06-23-2006, 12:39 PM
Re: Engine swap
Yeah, if you are going through all the work of an engine swap might as well do it right. The 305 is pretty gutless in my opinion. If you're really planning on doing it you might as well go with a 350, you could still go carburated if that is the way you want to go.
2006 Hyundai Sonata
Old 06-23-2006, 12:48 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Engine swap
Originally Posted by CamarosRsweet94
The 305 is pretty gutless in my opinion. .
oh no you didn't!
Old 06-23-2006, 01:08 PM
Re: Engine swap
Originally Posted by wrightz28
oh no you didn't!
Oh, indeed I did good sir
2006 Hyundai Sonata
Old 06-23-2006, 06:41 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Engine swap
all of this is true... except rear end is not a necessity (just making that clear) and you don't need to change the crossmember (assuming you use the same model transmission).
don't forget radiator and cooling system if you are doing a mild performance application. factory radiator will not be enough.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-24-2006, 01:33 PM
Re: Engine swap
im was planning on the 305 because i just graduated from high school and cash is tight. 305 are everywere and pretty cheap. Im not looking for a high horse power motor. Anything has more power then a 2.8, and whats the difference in gas milage between 305 and 350
Old 06-24-2006, 01:43 PM
Re: Engine swap
and its my daily driver till october, november. I can get a parts 305 car with no engine and tranny for about 400$.
Old 06-24-2006, 04:51 PM
Re: Engine swap
But if you are planning on doing an engine swap wouldn't you want the parts car to have these parts?
2006 Hyundai Sonata
Old 06-25-2006, 03:02 PM
Re: Engine swap
the parts car has no engine and trans, but it has the exaust,gauges, i need the seats and some plastic, it has nicer rims then the ones in my car, i can use alot of the pieces from the car
Old 06-25-2006, 03:30 PM
Re: Engine swap
Gotcha
2006 Hyundai Sonata
