Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-22-2006, 10:44 PM
cvguy78 cvguy78 is offline
brake caliper locks up
i have a 92 Ford crown vic. When i drive it, it seems fine, but after a while the brake caliper just locks up on the front driver side. Does anyone know why this might be happening??
Old 06-23-2006, 03:15 AM
KimMG KimMG is offline
AF - Advisor
Re: brake caliper locks up
Bad flex lines
Bad caliper
Old 06-25-2006, 01:25 PM
radioman2002 radioman2002 is offline
I'm not sure a bad flex line would cause it, but I would go with a bad caliper. When were the pads changed last? Was the bolts that hold the caliper on cleaned with a wire brush and new white grease put on it? How was the caliper pushed back when new pads were put on? Most of the new and especially the non-PD versions use a plastic piston, which can be canted, resulting in not moving back when the brake pressure is released. I would look at that first.
Old 06-25-2006, 01:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
The flex lines can cause the problems. They will deteriorate on the inside and a little piece of the rubber will drop down and cause a "one way valve". This does not allow the fluid to return quickly enough causing hydraulic pressure to stay against the piston in the caliper.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
