Old 06-22-2006, 05:06 PM
MrSandman's Avatar
MrSandman MrSandman is offline
Cylinder 4 missfire
Recently my SES light came on, so I took my car to Autozone and had them check it out. The error code it gave them was P0304 - clyinder 4 missfire. I guess that means I need to change my spark plugs and wires, since I haven't changed them since I've had the car. If that's the case, can anyone send me some info on changing the spark plugs in my car (a 99 GTP). Any help is always appreciated.
Old 06-22-2006, 08:23 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Cylinder 4 missfire
It is not hard to change the plugs and wires just hard to get to them. Start with the front and replace the wires one at a time. Make sure to set the gap properly and use AC or Autolite plugs. Don't use Bosch plugs. Also you may want to get a set of OEM wires from GM. You can get them from gmpartsdirect.com or rock-auto.com for a reasonable price. Once the fronts are changed you will have to either remove the dogbones from the front and rotate the engine forward to get to the rear plugs or risk some knuckles and use a ratchet with a u-joint to get to them. Rotating the engine is easiest but takes time and may require an engine lift to get it back into place. Good Luck!
Old 06-22-2006, 09:58 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
How many miles on the car?
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 06-22-2006, 11:26 PM
wlkjr's Avatar
wlkjr wlkjr is offline
I just changed my plugs and wires last week. The rear ones will give you fits. Practically have to be a contortionist the get at them and Stevie Wonder can change them as good as we can. It's an ordeal by feel. I think no. 4 is on the rear too. I had 180,000 miles on my wires and plugs and the plugs still looked good and was getting 25 mpg. First tank after changing I'm still only getting 25 mpg. Most likely the culprit is a wire as I had three go bad in the first 6000 miles but none since. To remove the wires you really have to twist the boots around to break them loose so they will slip off. I got a great deal on some AC Delco wires from Rich (richtazz) and prompt service too.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 06-23-2006, 10:32 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Thanks for the endorsement Wally, good service is my goal. With a flex head ratchet and a wobble extension, it's easier, but the mechanics by braille is a little difficult, gotta do it by feel for the most part. Another helpful tool is a pair of ring-nosed pliers to get the old wires off. The heat shields make it a pain to get a grip on them with your fingers.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-23-2006, 10:57 AM
wlkjr's Avatar
Both times I ordered parts from you I got them quickly. The service is excellent.
No way could I get any kind of removal tool on the back plug wires on mine. I just twisted and pulled the best I could. One of the plugs is right under some kind of sensor and it was the worst one. I did save a bunch of money though.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
