Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 06-22-2006, 12:43 PM
criii criii is offline
1991 735i clunks when shifting gears
I read a post from a really great user page (Driveline Carrier Repair) and I thought I had the answer to my problem. I checked and it's not the same issue.
When I shift to reverse or from reverse to drive there is a slight clunk if I let my foot off the brake to soon and not allow it to fully shift. It also makes the noise when driving at times when I accelerate.
Any thoughts?
Old 07-06-2006, 12:16 AM
Grettahouse Grettahouse is offline
Wink Re: 1991 735i clunks when shifting gears
Here's a couple of things to check:
1) Transmission rubber mount near tailshaft (where the drive shaft enters the trans.)
2) rear lower control arm bushings
3) C/V joints on rear axles
4) U-joints on drive shaft
5) Differential fluid
Hopefully you know what each of these things are, so you can check them yourself. Its usually a bad rubber bushing in one of these areas.
