Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-22-2006, 12:26 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
idle change after driving for a while
my car runs good when started up and stuff idles at like 8 or 900 rpms. but when you drive it for a little while and say you come to a stop light it will be at like 1500 sometimes 2k anyone have any ideas why it would do that. i mean it runs good and all that but it justs idles a little high and i worry about it
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 06-22-2006, 12:32 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: idle change after driving for a while
idle surge, pretty normal for our cars
if you want a temp fix you can unplug the tps and just adjust idle with the BISS screw, if you want to spend some money and fix it, look at testing out the isc motor and replacing if need be
now - 2000 civic
soon - 2002 is300
Old 06-22-2006, 12:43 PM
the isc on the car is brand spanking new. i had my ecu rebuilt and thats what caused it to blow so i bought a new one before i installed the isc.
but the idle doesnt surge at all i had idle surge when i first bought the car it holds steady at all times. it just after a while goes up to around 1500 and holds steady. but i will try it maybe the one they sent me is faulty
Old 06-22-2006, 05:41 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Clean your EGR valve. Mine is doing the same and the EGR is bad. Clean it out the right way, and see if anything changes. Should be the problem.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-22-2006, 06:07 PM
i dont have an egr valve i got a block off plate.
Old 06-22-2006, 06:55 PM
try to restart the ECU
unplug the battery for a few minutes, then try it again
now - 2000 civic
soon - 2002 is300
Old 06-22-2006, 10:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
I have a 6 pack on the throttle cable. When the car warms up the cable jacket expands, raising idle. This is exactly where I would start. Then look into other things if it's not the cause.
http://www.automotiveforums.com/vbul...throttle+cable
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
