Old 06-22-2006, 11:03 AM
its tahitian green its tahitian green is offline
HELP engine squeal rough idle issues
ok, heres the scoop. i did my rear disk conversion and while doing so i found i had to remove the intake to install the integra booster/master. while removing the intake i destroyed the main pcv hose and the one to the egr valve. of course it ran like shit while these were off, so i got new hoses from honda thinking ill replace and itll be good as new.
well i replaced them and it still runs like shit and now when you give it some gas it makes this horrible squealing sound that sounds like its somewhere around or below the intake. everything seems to be hooked up ok and i replaced the intake gasket as well. any ideas of what it could be? it ran fine with no squealing before i started this project and now im just lost. any help would be appreciated.
Old 06-22-2006, 05:12 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: HELP engine squeal rough idle issues
I think it's your alternator or the belt. Maybe the start of the noise is just a coincidence? Try removing the belt, see if the noise goes away. GL
Old 06-22-2006, 05:25 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
The squeal sounds like either a drivebelt or worse yet, your timing belt... i'd get that checked right away.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 06-22-2006, 06:02 PM
i feel strongly that it is not a belt. or the alt. the hose from the egr goes down between the intake plenum, that is where it seems to be coming from. what down in that area spins? it almost sounds like a bearing going bad of some type. remember it still idles rough and is slow to rev, once revved a bit is when it starts squealing. thanks for the replies though, hopefully there will be more.
Old 06-22-2006, 06:17 PM
johnb16a2's Avatar
Your welcome.
Hmmm, perhaps the tensioner going bad and the timing belt has jumped a tooth or two? Maybe a massive vacum leak inside the booster? Try disconnecting and plugging the booster vacum hose? Def needs more investigation.
Old 06-22-2006, 07:22 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
My CAI and TB squeal a little when I accelerate, only when im in this sweet spot with the throttle, any more or less and no squeal, its like a whistle from the intake..kinda drives me nuts, took the CAI off once and it quieted down but still cme from the TB some..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-24-2006, 11:16 PM
well i found it after some searching. turns out my shitty shadetree mechanics were to blame. when removing the intake a piece of the old gasket was left in the intake and causing the squealing as the air rushed through. doh! after some disassembly and reassambly and another gasket were back in business. thanks to all that replied, whod a thunk it?
Old 06-25-2006, 12:49 AM
FrodoGT's Avatar
haha, the simple things.. I tried for about 2 days to figure out why the hell my idle was steady at about 1500rpm, it was really beggining to piss me off, it turns out that while my intake was removed, a piece of wire loom (electrical tape) had been sucked into the TB and was still attacked to the harness...it was holding the plate open and causing my idle to go way up, when I finally realised what it was I kicked myself for a good 10 minutes..
Current project:
Rio Red 91 hatch.
