Old 06-22-2006, 06:20 AM
mountie1982's Avatar
mountie1982 mountie1982 is offline
Its Leaking But Dunno Where From
Well I head on out to my 97 blazer and i noticed a puddle under the front. DOH!!! I do a finger test and its a clear oil. HMMM. Its under the front passanger side kinda under the battery area. So under I go to take a look. What do I find??? Nuttin, not one trace of any leak. Double check to make sure i do see the oil. I do. WTF????? Could it be from the tranfer case??? or Could it be the hub??? Its all dry up under there so I am lost. There is a small knocking sound that started the last few days. Sounds liek a ball joint or maybe the torsion bar mount. You all got any ideas?
2006 Dodge Ram 1500 Quad
Why Dodge it when you can RAM IT?
1964 Vw Baja 1600
Old 06-22-2006, 06:52 AM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: Its Leaking But Dunno Where From
mine leaks from the dipstick tube when the oil is new. a puddles worth and thats it. is it parked on a downward angle?
Old 06-22-2006, 08:19 AM
Yea it is but the oil is clear. Not engine oil. Plus the oil was too far forward under the battery or corner of the front bumper. Dip stick is too far back.
1964 Vw Baja 1600
Old 06-22-2006, 01:24 PM
muddog321 muddog321 is offline
AF -Advisor
Hows the brake fluid - any leaks out the pass side hose or caliper?
Only other clear is PS fluid but other side.
Old 06-22-2006, 02:20 PM
drdd's Avatar
drdd drdd is offline
AirConditioning condensation dripping on the ground ?
Old 06-22-2006, 07:10 PM
magnum3456's Avatar
magnum3456 magnum3456 is offline
Banned
hahaha true....true
Old 06-22-2006, 08:23 PM
haha nope its an oil of some sort. I checked the brake fluid its all good. It had to have come from my blazer it the only car that parks there. I just dont know where. It not condesation dripping I live in Canada too cold for AC lol.
1964 Vw Baja 1600
Old 06-22-2006, 08:25 PM
magnum3456's Avatar
Banned
melting ice???? ahahah
Old 06-22-2006, 08:31 PM
Thats a good one HA HA HA
1964 Vw Baja 1600
Old 06-23-2006, 07:40 AM
AF -Advisor
Well, the bad news maybe that the intake is leaking and it runs down the block - or water pump. Look at the WP 2 holes by the bearing/seal for leakage. Intake look at the front seal where it meets the block and also between the valve covers and intake it can seep and run down depending on parking angle.
Old 06-23-2006, 12:05 PM
Well I found it. My oil cooler lines are leakign so bad that it has filled up the skid plate and other area that will hold oil. So the fuild is brand new engine oil that I poured in. I must have parked on a angle allowing the oil to drain out off the plate. I just have to shake my head at these trucks some times. I feel stupid. First for buying one second for getting stumped on this stupid problem.
1964 Vw Baja 1600
Old 06-24-2006, 12:45 PM
LS19962DRBLAZER4X4 LS19962DRBLAZER4X4 is offline
It could be Power Steering Pump Fluid, Tranmission Fluid, 4X4 transaxle
fluid Engine Oil... Dextron Antifreeze. People get cranky when the AC water drips out from the passenger side...
OIL IS BROWN
TRANSMISSION IS RED
POWER STEERING IS RED
DEXTRON IS RED
ANTI FREEZE IS GREEN.
Old 06-24-2006, 01:32 PM
rental blazer rental blazer is offline
Talking Re: Its Leaking But Dunno Where From
OIL IS BROWN
TRANSMISSION IS RED
DEXTRON IS RED
oh and to add to that list
water dipping down from a/c is clear
and purple means you have been smoking somthing it is reccomeed you wait til you sober up before working on a car..
Old 06-25-2006, 06:41 AM
AF -Advisor
Yep, been there too and the Dorman lines have better crimps and are available at most stores - oil drips into that plastic skid and into that frame cross member too and all Blazers owners who have not changed these lines should always look at the 4 crimps thru the oil filter door for fast or high leakage (most common place on 4wd - had a few 4wds that only dripped for many years before I changed them. But one kid came home one day and the line crimp had just blown out (2wd has 1 hose only and switches rubber to metal under radiator and didn't look there often cause filter is on block) and luckily had 1.5 qts oil left with rest all over the bottom of the Blazer!! That was a close one so change them out.
Old 06-25-2006, 07:22 AM
Its fresh oil, those lines must have been leaking alot to get it on under the opposite side of the vehicle.
