2000 SSEI Climate Control Problem
I just bought a 2000 SSEI with the duel climate control, which the riders side dash vents blow cold, but can't get the drivers side to blow cold. Anybody know anything about these?
Re: 2000 SSEI Climate Control Problem
It's either the temp actuator for the drivers side or you're low on refrigerant. The way the dual climate is set up, the passenger side blows thru the inlet half of the evaporator, and the drivers thru the outlet side. When the refrigerant gets a little low, only the passenger side gets cold.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
I've taken the interior out of the car and have the under side of the dash out. I've taken the actuator's out and the two on the drivers side seem to be working fine, but the riders side seems to act a little strange. I've talked to someone that seems to think I need to have it re-calabrated. Is that something that might need to be done?
All taken care of....Thanks for the help!!
Can you explain, so others may be helped with same issue.thanks
2000 bonn ssei 155000 klm 1997 dodge caravan 92000 klm |
Hello, I was reading your comments, and you had the same problem that i am having now with my bonneville, the A.C.. I Also See that you already solve it , can u please let me know how did you fix it because, i have been wasting my money and i still Have not fixed it, it is still throwing hot air on the drivers side and cold air on the passenger side. If you please Help me Reply back. Thanyou. [email protected]
Did u check refridgerant
