Old 06-21-2006, 09:20 PM
Myxlplyxxx Myxlplyxxx is offline
Question Easy One probably... 97 3.1 lumi...
Ok... about an Hr or so after drivin' My wife noticed the carpet and floormat on the pass. side was wet... well while she kept an eye on it I drove on... water(condensation Im assuming) was steadily drippin from under there about dead center... but only on acceleration and around corners to the left... so made a quik stop at a shop I know well and he said it was my drain tube for the A/C... so they put it up in the air and attempted to clear it(said it was probably plugged) used a coat hanger))no charge)... well its still drippin' same as before... Id like to fix it ASAP before it ruins the carpet and I get a small lake again.... any thoughts on what I should do next???
Thnx In Advance!!!
MYX
Old 06-22-2006, 03:10 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Easy One probably... 97 3.1 lumi...
There is a grommet where that tube passes through the firewall that may have fallen out or dry rotted. Instead of draining on the ground, it's draining inside the car.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-22-2006, 06:02 PM
I'll try that... they said they cleared it but obviously it didn't work so I'll ck that out BUT,... If that Isn't it then any other Ideas??? Could it still be plugged?
MYX
Old 06-23-2006, 11:11 AM
richtazz's Avatar
you may want to check the heater box itself. The plastic piece under the heater core and Evap core may be cracked.
