Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 06-21-2006, 07:00 PM
noyz25 noyz25 is offline
How do you reset the change oil light?
i changed my oil and want the light off.
some shop is charging me $30 to do this. i dont think it should be that hard or have to pay for it.
Thank You
Old 06-23-2006, 09:53 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Re: How do you reset the change oil light?
If your vehicle does not have the optional Driver Information Center (DIC), do this-Turn the ignition to ON, with the engine off.Fully press and release the accelerator pedal slowly three times within five seconds.Turn the key to OFF. If the CHANGE ENGINE OIL message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure.
If your vehicle has the optional DIC, do the following:Turn the ignition to ON, with the engine off.Press the MODE button until the DIC reads OIL LIFE LEFT/HOLD SET TO RESET.Press and hold the SET button until 100% is displayed.You will hear three chimes and the CHANGE ENGINE OIL message will go off. Turn the key to OFF.
Can't believe they want to charge you that much for a less than one minute procedure. Is it a dealership?
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 07-18-2006, 02:26 PM
rodeo02 rodeo02 is offline
The oil change icon should flash 3x if the reset was done sucessfully.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
