Old 06-21-2006, 06:50 PM
ward13 ward13 is offline
Unhappy Electrical Help Please
I have a 98 s-10 that all of a sudden would not respond to cranking. The battery is good/ the starter is good/ replaced starter fuse under the hood/ replaced park-neutral switch/ replaced ignition switch and still silent when you try to crank it. Do not know what else to do or try. If any one knows anything else to do please post a reply. I thank you for reading this problem.
Greg
Old 06-21-2006, 09:29 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Electrical Help Please
Greg
Welcome on your first AF post,
A good place to start or test is the starter relay.
See if 12 volts from ing switch and neutral saftey switches is getting to it when ign is in start position.
Also check small start wire at starter for 12 volts on ign start.
MT
MT
Old 06-23-2006, 06:41 PM
hueroloco hueroloco is offline
there's a 40 amp maxi-fuse and a relay in the UBEC (underhood bussed electrical center). Besides those I think you covered everything
Old 06-24-2006, 03:56 PM
Cam1959 Cam1959 is offline
Post Re: Electrical Help Please
Mine did that a week after having new stater motor and battery put in. A boost from my portable 700 amp starter got it going and been fine since. Something may be sticking that extra cranking amps from a boost may free up.
1983 S10 4WD carbed 2.8L automatic w A/C
Old 06-26-2006, 09:03 AM
BLAZERBOY69 BLAZERBOY69 is offline
Greg
DID YOU CHECK YOUR GROUNDS?
Old 06-26-2006, 08:10 PM
RahX RahX is offline
Thats a good way to fry the electronics.
