Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 06-21-2006, 06:05 PM
Arkie278 Arkie278 is offline
'99 Sephia won't start
Ok headed to the gas station yesterday morning, thought I ran out of gas and now the car won't start. Ive put gas in it, and Still nothing. Ive read it could be a ground problem, so I pulled the ground wire loose from the tranny and from the battery. Used sandpaper to clean all contacts and put it back together. Still nothing. Im getting upset. Any help will be welcome.
Old 06-29-2006, 10:21 AM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Re: '99 Sephia won't start
Try shaking the engine compartment fuse box while someone cranks the engine. The fuse box has contact issues for the fuel pump relay.
Old 02-28-2007, 03:51 PM
mdbakersr mdbakersr is offline
I have had starter problems with my 98 Sephia - have had 4 starters since I bought the car in1998. May be your problem.
Old 02-28-2007, 03:52 PM
Are starters a problem with 98 Sephias. I have put 4 in since 1998. Also what is a fair retail price for starter and installation?
Old 03-10-2007, 10:33 PM
click--it click--it is offline
hit the starter with a hammer
Old 04-08-2007, 05:48 PM
shadedarkan shadedarkan is offline
I have a '98 Kia Sephia that doesn't start sometimes. Now, it will die about twenty minutes after being on. I had a friend who is a mechanic for GMC look at it. We thought it was the fuel pump, but after extensive testing and error codes he found out the Crank Position Sensor wasn't reading the RPMs of the shaft and returning 0 which was causing the computer to turn off the fuel pump or not start it at all (when trying to start the car). I had to put a jumper across the fuel pump relay, but the CKP still has to be replaced. Now the car actually reports error P0335 for the faulty CKP circuit.
