Old 06-21-2006, 04:33 PM
skotman's Avatar
skotman skotman is offline
i replaced my main relay
car started right up, and always starts up no matter if it's hot, cold, whatever.
i'll never doubt you guys ever again.
Old 06-21-2006, 05:14 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: i replaced my main relay
/Slap, damn straight!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-22-2006, 04:17 PM
skotman's Avatar
i suspect, now, from reading, that the main relay in my sister's 87 crx is going out as well. it sometimes will start and then kill right away a few times before deciding to start for real. i read that's a symptom of the main relay going.
Old 06-22-2006, 04:46 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Is her CRX carbed? In that case i wouldnt be so definite it is the main relay. Do carbed cars even have a main relay? Could be the carb needs adjusting.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 06-22-2006, 05:05 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
hahahahaha i was picturing a slap on the knee and a banjo in the other hand. hahaha
Old 06-23-2006, 12:07 AM
skotman's Avatar
it's an SI. looks like MPFI to me, but either way, it's definantly not carbed.
Old 06-23-2006, 12:58 AM
FrodoGT's Avatar
Yeah its FI
Current project:
Rio Red 91 hatch.
Old 06-23-2006, 01:01 AM
If her car starts, idles for like a split second then dies that could be the ignitor in the distributor. Thats what mine was doing before i had it replaced. You might wanna check that. GL
Old 06-25-2006, 12:57 AM
GeneHer GeneHer is offline
I had a similar problem with my CRX - it would "die" whenever the engine was moderately hot.
Checked out an online site, which suggested reflowing (resoldering) the relay's little PC board. You can reach this by removing the plastic cover from the top of the relay.
You may or may not see little "circular" cracks in the solder joints. If so you can resolder these connections.
I used silver bearing solder on my main relay. Re-installed it. Don't even know I have a relay now. Hot, cold or whatever. Always starts.
Another thing, in case anyone cares; the relay on my car was on the left hand side of the dash behind that "change' drawer. The Chilton's manual had it drawn behind the fuse block. Yeah, I did go looking for it.
Gene
