Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-21-2006, 04:21 PM
noholdsbarred noholdsbarred is offline
Question Plug gap?
This question may have been asked before, but I tried searching the different forums and came up with nothing. I found info on NT engines, but I have a turbo engine. I need to know the proper spark plug gap. I only ask this because the sticker under the hood is completely worn and I don't have a manual. Thanks.
2004 Impreza WRX
Old 06-21-2006, 04:47 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: Plug gap?
What plugs are you using? For my ngk brp7es I have them gapped at .028 If you are running more than 20psi of boost I would gap them a little smaller.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 06-21-2006, 06:20 PM
Killa's Avatar
Killa Killa is offline
Re: Plug gap?
NGK BPR6ES gap at .028.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 06-21-2006, 06:49 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Plug gap?
It varies slightly, but people usually end up gapping them between 0.028-.032
The best thing you can do it gap them, and try them out. If it misses or just dosn't feel right, pull them out and change the gap slightly until you find something that works good for you.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-22-2006, 12:10 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Plug gap?
I had mine set at .032 but now I will be setting them to .028.
Thanks crunchy.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-22-2006, 12:12 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Plug gap?
.028
now - 2000 civic
soon - 2002 is300
Old 06-22-2006, 12:23 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Plug gap?
I would recomend everyone run 7s, there is really no need to stay so hot at 6. The 7s self clean fine, and are even stock in the EVOs (well, the iridium version). I'm currently running non-projected 8s in the EVO, and they are still good a week into it (no idle/cruise misfire or fouling). If they last I'm staying with them. I am REALLY starting to like the idea of non-projected plugs. For anyone that wants to try them out, just take the "P" out of the part number. For example, BR7ES.
For people that would like to experiment, or buy plugs from non DSM vendors like summit, it helps to know what the part numbers mean. For example, in BPR8ES, the B is 14mm, P is projected, R is resistor, 8 is the heat range, E is gasket type seat, and S is single/standard side electrode. This is off the top of my head, so don't hold me to it, but you get the idea. Basically what we fool with is the number, and the P or lack thereof. Summit carries every NGK plug imagineable, 1.99 a piece isn't too shabby either. You can get it down to under 2 bucks locally by buyng cases, but I love dealing with summit.
I'm running a 25 gap lately, but 28 served me well for many years. On a bigger setup like my old 2g, you may have to go as low as low 20s. Any lower than that most poeple start to have problems. Ultimately, you want the biggest gap that doesn't misfire. There are MANY factors involved in that however.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-22-2006, 03:06 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Re: Plug gap?
Once again, thanks Kevin for your great posts and the time it takes to write them. Always extremely informative.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 06-22-2006, 09:33 AM
Killa's Avatar
Re: Plug gap?
So its ok to run 7ES even Im stock ??
GM FOR LIFE !!
95 camaro lt1
Old 06-22-2006, 10:25 AM
AF - Advisor
Re: Plug gap?
Yes, in my humble opinion. If you ask me, it's cheap insurance. Turbo car owners should be changing plugs every one or two oil changes, the factory probably used 6s only because the average non-enthusiast doesn't change plugs until they don't work.
Kevin Jewer
Old 06-22-2006, 01:51 PM
Re: Plug gap?
Agreed, it is always a treat to learn something new from Kevin....and that happens almost every post it seems.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 06-22-2006, 09:59 PM
AF - Advisor
Re: Plug gap?
You guys are making me blush.
Kevin Jewer
