AC Output dies on hills
I have an Express 1500 conversion van and the ac dies on hills or when the engine is strained. Sounds like a vacuum problem to me. Any suggestions on why it is happening and what to do? Seems to me that a high reving engine would cause more vacuum than less.
Re: AC Output dies on hills
Year would be helpful, but yes does sound like a vacuum problem. Does air then blow from the defrost vent when under load? Find the vacuum reservoir and make sure it is connected to vacuum and doesn't leak. Under load an engine has none or less vacuum than when at idle or steady state cruise. It has less vacuum since the throttle is open (or wide open) and manifold pressure is closer to atmospheric pressure. Think, whenever the throttle is closed and you have a cylinder on the intake stroke, (intake valve open, piston going down drawing in air/fuel.) the throttle blade acts like a restriction to atmospheric pressure and the piston creates a "void" or negative pressure in the intake manifold. With the throttle open you have less restriction and equalize the pressure inside and outside of the engine hence less vacuum. That is why on a hill under load and have a leaking vacuum reservoir you lose that negative pressure and the hvac defaults ( goes to defrost or the normal position)
Sorry for the long post and hope I didn't cause more confusion than good.
ASE Master ASE Advanced Engine performance GM World Class Technician 1978 Pontiac Trans Am 1984 Monte Carlo SS 1991 GMC C1500 2002 Pontiac Grand Prix |
Thanks for the info, my van is a late 96 1500 express, first model in production, I bought some factory manuals on a 1997 which seem to apply but I don't see any diagrams or pics showing vacuum routing. do you know a good source?
Also make sure the compresser is not shuting off under a load or wide open throttle. MT
