Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-21-2006, 12:06 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
front left wheel wierd movement...
Well for about a week now every time i turn the wheel at all left of dead center, there is sort of a scraping noise coming from the front left wheel. I finally jacked it up and was seeing if redoing all of the lugs was the problem when i noticed that the whole wheel and caliper move when you jerk it. It is moving in a camber kind of way like one hand on the top and one on bottom and rocking it. I jacked up the other side and it is solid, so what can the problem be????
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 06-21-2006, 01:02 PM
Re: front left wheel wierd movement...
could it be the tie rod?
SOLD
'97 GSX
Old 06-22-2006, 11:18 AM
nobody has even the slightest idea?
SOLD
'97 GSX
Old 06-22-2006, 10:33 PM
kjewer1 kjewer1 is offline
AF - Advisor
I got a 6 pack on the balljoint on the outside of the lower lateral link. I've posted elsewhere on this site how to test for this.
Here is one thread
This is a safety issue, it this is what it turns out to be. Get it fixed!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-22-2006, 10:44 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Doesn't the dealer have to warranty the lower balljoints if they are found to be bad? I know they have to warranty something in the suspension and I'm pretty sure it's the balljoints.
95 Talon TSI AWD
97 Eclipse GST
Old 06-22-2006, 10:45 PM
AF - Advisor
They were recalled on almost all 2Gs. They have various ways of getting out of covering it though. Definitely worth a shot.
Kevin Jewer
Old 06-23-2006, 11:40 AM
Fallenfantasies Fallenfantasies is offline
if you are moving it like with your hands and the lug nuts are tight then it is the hub bearings. if you go get your car align they should be able to put new ones on for a decent price. i had my car slammed on coilovers and a pothole started makin mine do that and they just put new wheel bearings on it and it was fine
Old 06-24-2006, 01:11 AM
When wheel bearings go out, 95% of the time they will give off sort of a "humming" or low growl noise when you're driving. Thoroughly check out the suspension/alignment parts, and if all else fails, replace the wheel bearing. It never hurts to have a new one in
95 Talon TSI AWD
97 Eclipse GST
Old 06-24-2006, 01:16 AM
AF - Advisor
Most modern bearings don't develope any real slop when they wear. They will make noise, and sometimes you can feel a grinding while rotating by hand. In my experience, it's not like the good old days when bearings got real loose.
Kevin Jewer
Old 06-30-2006, 05:16 PM
jsb1369 jsb1369 is offline
Hey just to let you guys know my eclipse was great i could get her up yo 120 on the highway. the other day i was doing about 30 on some back roads when it jumped and suddenly started pulling to the right. well she lost a balljoint and the wheel jamed under the body, skidding over 80 feet. I got lucky i was about 5" from the curb and 1' foot from a telephone pole. After it happened i did reserch and found it to be defective. The ins. co. said its 1200 dollars to fix all the broken parts on the one side. If I get it done ill do both sides. I love that car but i cant look at it the same way.She only had 94,000 miles. Do your suspension work first.
Old 06-30-2006, 09:59 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Thats very... interesting...
Sounds like you should be driving a little more carefully, but thats just my opinion...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-01-2006, 04:17 PM
AF - Advisor
Doesn't matter how you drive if you lose one of these balljoints, or have a Tcase lock up. People have been killed by these things. Get these recalls done! Or at least get the parts and fix it yourself in the case of the Tcase recall.
Kevin Jewer
