Old 06-20-2006, 10:59 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Thumbs down Problem on Passenger side floorboard
Ok here's the deal. I was running the RCA cables for my amp and I pulled up the passenger side carpet, and much to my dismay the carpet and padding is soaked. Now it is just water and not antifreeze (I already did the search on the problem and found nothing to help)
So after digging around and checking out all of the could be's I just decided to look on the floor to see if there is a hole of some sort. To my suprise there is, BUT it looks like it is something from the factory. It is about 3inches in diamiter and kind of an oval shape. It has a fill piece that looks like it was welded in but the welds broke and now is very loose.
I am going to tak pictures of it tomorrow and post them on here so maybe someone can explain what the hell this thing is. If you have had this problem or even know of it PLEASE help me out here. I am now going to have to replace all of the carpet because of the very bad smell that is now produced frrom the very wet carpet and padding (I didn't smell anything until I actually pulled the carpet up)
Also if you know of any place that sells pre molded carpet for a 2000 Blazer 2 door let me know.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 06-20-2006, 11:04 PM
SComp23 SComp23 is offline
Re: Problem on Passenger side floorboard
Stylinconcepts.com does, but it is expensive, like 300 bucks for a carpet set-up.
Old 06-20-2006, 11:14 PM
BlazinMlew's Avatar
SComp Thanks for that info. I checked them out and all they have is 4 door.
I did however search the web and found this nice little site:
http://www.stockinteriors.com/AutoCa...=31&ModelId=93
For anyone else who might need theirs replaced.
Old 06-20-2006, 11:30 PM
There is a guy down here in Sarasota on ebay named s10warehouse, you might wanna shoot him an email, that is really expensive he could probably get one for you cheaper, it would be used however.
Old 06-21-2006, 01:46 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Just dry it out and check to see that your AC condensor drain is not plugged up.
You don't have to replace the whole carpet just because it is wet.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-21-2006, 07:29 AM
BlazinMlew's Avatar
The carpet is pretty well shot anyway so I figure I might as well just put in a new one. The salt from my shoes has pretty much eaten away alot of the color (turned it to a nice shade of crap brown/gray)
I have looked at all of the obvious reasons why the wetness would be there (A.c. condenser drain, weatherstripping, ect.) but it just seems to be that hole and nothing else.
Scomp thanks for the info again I am gonna search for that guy right now and see what he's got.
Old 06-21-2006, 08:40 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Check the drain and also make sure you always keep the air intake by the windshield clean of debry, I had some leaves plug up the catch box down there and was causing the water to run down the firewall onto my carpet. Once fixed carpet dried and everything allset.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 06-21-2006, 11:49 AM
BlazerLT's Avatar
AF -Advisor
True, and also invest in some floormats.
Old 06-21-2006, 01:29 PM
I agree, I think Weathertech is the best. IMO
K&N Air Filter
Old 08-22-2006, 01:12 AM
97BlazerLT's Avatar
97BlazerLT 97BlazerLT is offline
Send a message via MSN to 97BlazerLT Send a message via Yahoo to 97BlazerLT
I have the same problem -- Where is this hole??? I looked and I can't find anything - I have my blazer all torn apart drying out the carpet. Windshield looks good -- this drain for the windshield -- where does it run -- and why would it come along the firewall on the inside?? And yes it is water -- no antifreeze. - but a quick note - I dont know if it has anything to do with it but my AC worked last summer and this summer it dont -- and it was this spring that i noticed a mold smell and this last weekend i found out where the smell is coming from. But i an mot sure why its wet yet - ANy helo that would be great!! I am glad I have a back-up car while my Blazer is drying out
