Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-20-2006, 01:22 PM
scherp scherp is offline
95 Olds Supreme Ides fast when cold
My 95 cutlass supreme (3.1) idles between 2000-2200 when the engine is cold. when the engine temp is about 150 degrees it will idle down to 1200 and stay there. I replace the air temperature sensor and that didn't help. The check engine light doesn't come on if you are driving, but will if l let engine idle.
A few weeks I had to take off the upper air intake manifold and TB to replace a o-ring on the oil pump drive shaft. Does anyone know what sensor might be causing the high idle when cold.
Old 06-20-2006, 03:20 PM
maxwedge maxwedge is offline
A990 racer
Re: 95 Olds Supreme Ides fast when cold
You need to scan it and check the code first, also make sure you connected all the sensors in the area that you worked on the engine, including vacumm connections.
Old 06-20-2006, 11:48 PM
s281er238 s281er238 is offline
Exclamation Re: 95 Olds Supreme Ides fast when cold
Replace The Tps And Aic Sensors Then Ur Set
Old 06-21-2006, 07:41 AM
A990 racer
Lightbulb Re: 95 Olds Supreme Ides fast when cold
And we know this how in this situation?
Old 06-22-2006, 10:57 AM
The car is running normal again. I did change the air temp sensor, unplugged the TPS and reconnected it and made sured all the vacuum hoses were fitted correctly. Thank you all for your help.
