Old 06-20-2006, 12:27 PM
carlosdaroo carlosdaroo is offline
Granatelli Mass Air Flow Sensor
Anyone installed one of these in their Chevy Blazer? I have a 2000 Blazer that is running pretty good except that the mileage could be better. The mileage was really bad until I noticed that the thermostat was not functioning correctly. The truck was running at on 62 degrees so it must have been stuck open. Anyhow, someone at the shop mentioned this Mass Sensor and said he got about 70 to 80 kms extra per tank full of gas, not to mention the added HP.
Any thoughts would be appreciated and also if this can be sourced up here in Canada? I have found it online from the US as cheap is 325 US but would love to get it cheaper and if possible in Canada.
Thanks and great forum.
Old 06-20-2006, 05:30 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Granatelli Mass Air Flow Sensor
Welcome on your first post on AF.
I would proceed with caution on that one.
What is good for the goose may not be good for the gander or in other words.
What may work on one car may not do good on another one.
If you lean it down to much you may burn valves and pistons.
MT
MT
Old 06-20-2006, 08:45 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Do NOT install it on a 4.3L if you want it to run properly.
Many people have installed it only to go back to stock.
Put the money into a good tuneup.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-20-2006, 10:06 PM
Thanks for the great advice, it makes sense. I will get a good tuneup and see if my mileage does improve. I am getting around 360 to 380 kms on a full tank and I think i should be over 450 no? I believe thats what I was getting before I noticed that my Thermostat needed to be replaced.
Thanks again
Old 06-20-2006, 10:36 PM
BlazerLT's Avatar
AF -Advisor
Thanks again
I get 400-425 per tank all city driving and that is on a 1995 with 237,000kms on it and big 18 inch wheels and a big subwoofer box in the back.
Do the following and you will get better mileage:
Fuel filter
Spark plugs AC Delco Platinum only
Cap & Rotor
Air Filter
PCV Valve
Transission flush and refill and a new filter
Differential fluid and transfer case fluid change
O2 sensor change if over 150,000kms.
Let me know what has been done. Don't wait any longer to get an improvement, you are not in good shape as it is.
Old 06-20-2006, 10:41 PM
SComp23 SComp23 is offline
Fuel filter
Cap & Rotor
Air Filter
PCV Valve
That's what, 250 miles per tank? I get about that also, when I am driving mostly highway I get about 300-310 miles per tank. I do agree with LT however, the MAF you are speaking of willl cause more harm than good, do a good tune up and see if that helps.
Old 06-20-2006, 11:06 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
I installed a new MAF on my old 88 Mustang GT when it was stock and got close to nothing for a gain. The only true gain came after replacing the heads and cam.
I imagine it would have tot be the same if not worse for a more sophisticated computer controled vehicle such as a Blazer or Jimmy. (ie:4.3L)
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 06-21-2006, 05:05 AM
muddog321 muddog321 is offline
AF -Advisor
You never said if all city stop and go or highway.
Depends on how many miles divided by gallons (Km div liters) to see actual because are you putting 18 gallons in or 15??
Gears also matter cause the 3.73 get lower than the 3.42 and 4wd also is less due to the xfer case and front drivetrain.
Old 06-21-2006, 11:51 AM
BlazerLT's Avatar
AF -Advisor
I drive servere city with all stop and go and get over 400kms a tank, him getting that low at 350kms to 380kms in either situation is a sign that something isn't up to snuff.
Old 06-21-2006, 03:04 PM
goser goser is offline
Fuel filter
Cap & Rotor
Air Filter
PCV Valve
Blast, I didn't think I was doing that bad with ~380km to a tank highway driving. New O2 sensor here I come...
Old 06-21-2006, 03:33 PM
NOVA71's Avatar
NOVA71 NOVA71 is offline
Yeah, I get about 370-380 kms per tank as well with my 2000 Jimmy. All city driving. Even after new plugs, wires, cap and rotor, air filter, oil & lube (all ac delco parts of course). Still getting the same milage. Buy hey, I don't mind feeding a good horse. However, if the horse goes bad, I'm getin my gun!
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 06-21-2006, 06:33 PM
MT-2500's Avatar
AF - Advisor
Work on the tune up end.
Plugs and filters and stuff like that first.
A 02 sensor will not help unless your old on is bad.
Plus there is 4 or 5 02 sensors on there.
MT
MT
Old 06-21-2006, 06:55 PM
BlazerLT's Avatar
AF -Advisor
Might want to consider changing the O2 sensor before the cat.
Old 06-21-2006, 07:31 PM
MT
Yeah, I've done pretty well everything else within the last year, save maybe the thermostat...until i heard BlazerLT's mileage I figured just under 400/tank was the best it was going to get. She's still a good horse...but this is getting off topic
Old 06-21-2006, 10:01 PM
BlazerLT's Avatar
AF -Advisor
Not really, it is all related.
