1st my mods:
3.6" MPS with 660(66.8") s/c belt DHP PCM w/15* stock timing AFC 2.2/LS1M PEMs(Ported Exhaust Manis) 3"DP-Hi-Flo Cat-2.5" U-Bend Delete/Resonator Delete-Stock "Y" and Stock Mufflers 180* T-Stat [email protected] 4"FWI(Fenderwell Intake) ZZP Fuel Pump Rewire With the AFC at idle/cruise they're slightly negative but very close to 0. heres a scan: http://scandepot.net/viewscan.php?pk=2388 i tested the Fuel Pressure and its at 40PSI at idle and holds there. when driving and at WOT, it'll hit ~50PSI, decrease as i increase in the RPMs to ~44-45PSI, then it'll spike back to ~50PSI at the start of the next gear then it'll decrease again as it increases RPMs. i also disconnected the FPR vac line and the Gauge went from 40PSI to 48PSI. I replaced the following Parts to these: stock Fuel Pump to 40K fuel pump stock FPR to a used FPR stock injectors to 50K injectors New Purolator Fuel Filter after all of this im still getting Lean O2s and getting as much as 20-21 on my injector cycles and hitting alot of K&R. as much as 5-6* at WOT. i am currently testing the voltage on my fuel pump connector and see if its loosing voltage to the fuel pump. but if anyone has any suggestions for my problem that would be greatly appreciative. fst100 Edit-also i checked all the fuses and relays and they are fine. also i didnt see/feel any kinks along the fuel lines. Last edited by fst100; 06-20-2006 at 09:32 AM. |
Re: lack of fuel at WOT
The fuel pressure is too low for the mods. What year is your GTP?
I have nothing less than 45 psi at idle with vacuum connected at the FPR. I see you installed a used FPR but have you considered a higher output like the Casper. What rating are your fuel injectors in pounds of flow per hour?
98 GTP
i'll be getting another used FPR from a local member. I was thinking about the casper AFPR, if thats what you're suggesting, but its a bit expensive for now(getting an alky kit in the mail). my injectors are stock injectors with 50K miles on them. cant remember the stock # they flow, but im guessing 36 or 39 is coming up in my head at the moment. |
minimum fuel pressure spec is 48-55psi key on, engine off. It looks like your issue is low fuel pressure.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
If you can get flow up at the higher rpms or 3 - 5 psi you should be OK but you are low compared to what I've seen. Yes, I was referring to the Casper adjustable. Try the replacement FPR. They vary in what they flow and put out. The Purolator fuel filter is OK but the AC Delco flows better.
The fuel pump has two speeds.
I understand the fuel pump has two speeds, and the PCM primes the fuel rail/injectors using the high speed circuit. This check ensures proper fuel pressure for the vehicle to start. What is the fuel pressure reading key on/engine off? THe fuel pressure reading seems borderline at best while running from what I'm reading. Just my 2 cents.
As a matter of fact a L36 SE/GT will not read 48-55 psi in the pump prime position (key on/engine off). The so called textbook reading of 48-55 is with the engine running at idle and vacuum removed at the fuel pressure regulator. The poster gets 48 psi in that condition. Quote:
A Casper adjustable fuel pressure regulator makes up for that deficient area especially if the engine is modded. Also, note that the poster has a ZZP fuel pump rewire kit which is supposed to illiminate the fuel pump resistor and allows the fuel pump to get a higher input voltage and current wise due to the poor stock wiring. Casper makes one similar called the Hotwire. The purpose is to prevent a lean condition. From what I can see he is 2 - 4 psi low for what is typically normal. However, in an unmodded GTP that might work out fine. Where I agree is his readings are low as I previously stated.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 06-20-2006 at 07:56 PM. |
couldnt get the FPR from my friend to work, his was an 02 while mine is a 98. seems like the 97-98 were different than the 99+ >.<
will i tested the fuel pump adapter. there are 4 wires on the fuel pump. purple-fuel level sensor grey-fuel pump sensor black-ground black w/white stripes-cant remember but its irrevelant in this situation took a multimeter and probed the pin on the grey wire and grounded the other probe needle to the chassis. i had someone prime the fuel pump. supposely, the voltage from the fuel pump sensor should read ~10-12volts, but mine didnt even move, not even when we started the car. now im thinking its an electrical problem. but i cant seem to find where the wiring harness goes under the trunk. |
Maybe you are referencing to a bad ground. The gray wire is the pin B input to the fuel pump (hot). The black wire is pin C to the fuel pump (ground). Is the multimeter set for DC Volts? Try putting the red lead on gray/pin B and the black lead on black pin C at the connector plug. How is that ZZP rewire kit wired into the circuit? The other thing you can do is go point to point and check for continuity between the connector at the fuel pump and back to the fuel pump hi-speed relay in the engine compartment fuse box. However, you will need a one long meter lead to do this. BTW - It would be impossible to get the car running or have any fuel pressure reading if the wiring was really that bad like an open or short. Edit added: The fuel pressure regulators are supposed to be the same for '97 - '03 GTP models. My book shows the same part number.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 06-20-2006 at 09:41 PM. |
"Maybe you are referencing to a bad ground. The gray wire is the pin B input to the fuel pump (hot). The black wire is pin C to the fuel pump (ground). Is the multimeter set for DC Volts?
Try putting the red lead on gray/pin B and the black lead on black pin C at the connector plug. How is that ZZP rewire kit wired into the circuit?" i did put the red lead on the grey/pin B and black lead on the black/pin C, and still no reading. The ZP Fuel Pump Rewire is wired in the inside of the car, i opted and did not do the 100% method of extending it all the way to the engine bay. Still, the Fuel Pump Rewire is wired correctly, otherwise my fuel pump wouldnt' even power on with the key turned. About the FPR, i mistyped that, the FPR i got from the local came from the L36, which is very different from the L67. he nor I knew of the difference(didnt have a manual unlike some of us :-p) im gonna rule out the FPR since I'm not getting any voltage from the fuel pump sensor when i should >.< a friend i know recommended taking an 18 gauge wire and use it to 'directly' connect the battery to the grey wire fuel pump sensor since its alread hot. im gonna have to cut the grey wire to then connect the 18 gauge at the fuel pump adapter. of course i'll put a 15amp fuse in between the battery and the grey wire. im also gonna hook up a switch so i can turn the voltage on whenever and see if there is actual voltage going into the fuel pump sensor. it'll look something like this: battery (+) ->15amp fuse holder -> On/Off Switch -> Fuel Pump Adapter once that's in i'll take the car out on a drive and also hook up my Fuel Pressure Gauge Tester and check on whats my FP at WOT. To see if it'll go up as high as 52psi as the target with my mods. What do you think? any other suggestions? |
"The other thing you can do is go point to point and check for continuity between the connector at the fuel pump and back to the fuel pump hi-speed relay in the engine compartment fuse box. However, you will need a one long meter lead to do this."
Yea i dont have a long enough cable to use unfortunately >.< i forgot to mention, i did replace the Fuel Pump Relay as well as the Fuel Pump Hi-Speed Control Relay. Still a No Go |
It sounds like you are on the right track and your troubleshooting technique looks good but I do have a reservation. The problem (checking voltages at connector) doesn't make sense. With the connector at the fuel pump connected do you hear and feel the fuel pump prime at key on/engine off? The last time I checked when ignition is switched to on fuel pump prime only lasts about two seconds. Therefore, there will only be voltage at the fuel pump connector for a few seconds. You can repeat by taking ignition to off then back to on while checking the voltages.
when i turn the key to the "On" position, the pump will prime, i can hear it even if the middle fold-up/down elbow rest is closed off. it'll last for ~2-3 seconds, so the pump is priming the line with fuel. trust me i went and checked the red lead to grey pin and black lead with either chassis or black pin for the 2-3 seconds the pump was priming. i know this doesnt make any sense to me either. its just mind boggling.
Edit- yes i turned the key on and off testing different ways to see if theres voltage going. i even, again, started the car to see if there was voltage, although i think im killing my starter-turned key to "Run" and didnt click a couple of times in different instances >.< |
From what I can see the wiring from the engine compartment fuse box to the pump appears to be good since the fuel pump does operate. But it would be nice to know if you are getting full voltage to the pump with no voltage drop due to degraded wiring or high resistance. At least for piece of mind and ruling it out as a problem. Good luck!
