Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-20-2006, 04:44 AM
swiftrecon swiftrecon is offline
Red face choking problem...where do i start?
my bro has a problem with his car. i don't know what car it is, i believe it is a general problem applies to any car. it chokes a little when idle or put in gears(what gears? doesn't really matter!!). and also chokes a little bit when crusing. if it chokes too bad, the car just die. the car has never been modified, stocks and old!!
i think this probably indicates fuel system problems.
1/O2 sensor
2/MAP sensor
3/fuel pressure(or fuel filter clogged)
all i know is that car probably doeson't have a working O2 sensor. but my bro insist me to prove that. any know how to check a O2 sensor?
or any other problems i should look into this matter?
any feedback on approaches and procedure are great!!
thanks,
Old 06-20-2006, 12:49 PM
somick's Avatar
somick somick is offline
Re: choking problem...where do i start?
As far as I know the bad O2 sensor will cause the check engine light to come on. I would start with regular maintenance: spark plugs, wires, distributor cap.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-21-2006, 07:19 PM
yep! just found out that dist. cap's 4th wire is burn pretty bad. thanks for the pointers, good job team...
