Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-19-2006, 09:15 PM
shawnmd shawnmd is offline
96 Neon Start Problem
I believe the starter is gone on my 96 sohc neon again. Can someone tell me how I can jump the solenoid to see if it is the problem. Changing the starter on these cars is a pain... I used to jump the solenoid on my old ford truck and it was easy but on these--I dont know. Anybody
Old 06-19-2006, 11:06 PM
Wollf's Avatar
Wollf Wollf is offline
Re: 96 Neon Start Problem
There is a clip on the top of the starter with one wire attached to it , if you short that to the posative it should turn your starter over. and on a side note , i found that if you just remove the fan on the right side of your rad , facing the engine its not so bad to re and re your starter , i had to do it a few times when my new one failed after one day , and i had it down to about 30 mins to change out.
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Old 06-21-2006, 09:42 PM
HPNOTIQracing HPNOTIQracing is offline
or you could check the timing belt.
Old 06-21-2006, 10:00 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
What's make you think that? What is happening?
Old 06-22-2006, 04:06 PM
The car was just clicking when I try to start it. I found out that it was a loose cabel. It was the smaller red cable that connects together on the positive side of the battery. Working now.
Old 06-23-2006, 11:53 AM
Funny how people overlook the simple stuff first. Glad to hear it's up and running again.
