Old 06-19-2006, 09:14 PM
arix arix is offline
02 sensor replacement
Hey all gurus,
I have a rookie question about where are these o2 sensors located? After an oil change the other day the mechanic said I have a bit of a rough idle, which I have noticed. He then recommended the 02 sensors replaced, but at $99 each, I told him I'd wait. The parts are about $20 each on ebay, and they look to just be plug and run parts. I know there are the up stream and downstream versions, but where the hell is the stream. lol. Also should all 4 be replaced, my 5.3 engine has about 165,000 but runs like a champ. Any body replace these things?
Old 06-20-2006, 12:19 AM
2000CAYukon 2000CAYukon is offline
Re: 02 sensor replacement
Upstream is before the cat (i.e. between exhaust manifold and cat) Downstream is after the cat (between cat and muffler). The downstream cats do not affect preformance and are only used to monitor cat performance. Therefore, the upstream 02s should only be replaced.
Do they need to be replaced? It depends. A dirty throttle body can cause a rough idle as well as a leaking fuel pressure regulator? With 165K, it could not hurt to replace them.
//2000CAYukon
Old 06-20-2006, 07:06 AM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
Just a quick question to piggy back on arix's post and what 2000CAYukon said.... Would it be benifical from the preventitive maintenance point to replace them anyway if you have over 100k miles? My truck runs good but does have a slight ping when I step on it and the throttle is at just the right spot.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 06-20-2006, 09:51 AM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Mine threw an ses light, and when I hooked up the palm to it, it told me it had a bad 02 sensor. The truck started idling rough and my air/fuel gauge started acting crazy as hell(the one pigtailed into the driver side sensor). Until it threw the light, everything was running perfect, so I wouldn't change them until I threw a light telling me too. Mine had 146,000 on it before it went bad.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 06-20-2006, 08:25 PM
fleettech fleettech is offline
If it doesn't throw a light there is probably nothing wrong with them. Most times an O2 sensor code is caused by something else upstream. it does not matter how many miles you have unless you like wasting money you gain nothing by just swapping them out.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 06-21-2006, 12:34 PM
jeep_cj4x4's Avatar
ok, I was just wondering if an O2 sensor was something to do for preventative maint. Like changing a belt thats getting cracked. As for wasting $$, I'd rather spend $20 now than break down later.... but I'll save my money instead.
Old 06-21-2006, 05:48 PM
justinp01 justinp01 is offline
I would look into getting a throttle body cleaning (generally from the dealer), it did wonders on my '01 with only 80k miles.
Old 06-21-2006, 05:59 PM
NoRiceHere01 NoRiceHere01 is offline
i would buy O2 simulators and gut the converters hahaha
Old 06-22-2006, 09:56 AM
I got the rear cut off in the tuning and just cut off the converters. The front has to stay on though.
Old 06-22-2006, 03:44 PM
Thanx for all the suggestions guys,
Well today I noticed that there is a loud whining noise coming from the gas tank. I'm thinking the rough idle could in part be attributed to my fuel pump being on the verge. It sounds like it is straining, but dies down once I get going. I know from my last truck it is a pain in the @$$ to replace. We'll see how long it lasts.
Thanx
Old 06-24-2006, 12:27 PM
Bobby56 Bobby56 is offline
The fuel pump on my 2000 5.3 has been loud for the past 50,000 miles, though sometimes the sound goes away. I've been telling myself that it's due to the placement of the pump - maybe against something that transmits sound. I'll go with that until the pump quits.
