Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-19-2006, 06:57 PM
smith5170 smith5170 is offline
Angry 94 wiring diagram for heat/ac controls
I am looking for the wiring diagram(s) for a 94. The control for the heat/ac will not change the place that the air comes out of. It is stuck on def./floor. I have looked in the Haynes book and it has everything except for what I need. I replaced the temperature control panel and checked for vacuum. PLEASE HELP!
Old 07-07-2006, 03:27 PM
loetman loetman is offline
Re: 94 wiring diagram for heat/ac controls
i think that is a vacuum problem.
have you checked the electronic/vacuum Box (you see an picture in the Haynes Repair Maual on Site 3-13 illustration 11.8) i had the same problem, by the box was an hose away from the Box.
you can also test the vacuum when you pull a hose of and the engine runs you must hold a Finger of the open vacuum connector and you must feel the vacuum.
2. you have an vacuum-valve that regulate the rear heater. perhabs there is an acuum Leaking.
i hope that helps you!
