Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-19-2006, 06:02 PM
pballerlax42 pballerlax42 is offline
Heat shield
My heat shield is raddling and making like "pinging" very nasty noises, is it ok to take it off? Or will bad stuff happen?
Old 06-20-2006, 06:18 AM
WReX WReX is offline
Re: Heat shield
it is there for a reason so i wouldn't take it off but what you can do is get 4 big hose clamps and connect two together and rap them around the heat shield in the front of it and the rear, tighten down until they are snug....that should help quiet the rattle if not then look into a new heatsheild or something
26 PSI anyone?
Old 06-20-2006, 03:16 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Heat shield
which heat shield is rattling?
It wont hurt anything to take it off.
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-20-2006, 04:29 PM
Re: Heat shield
not exactly, if its the catalytic converter heat shield its there to keep heat in/around the cat so that it works properly...
26 PSI anyone?
Old 06-20-2006, 06:07 PM
Re: Heat shield
its the heat shield around the cat, now there is 2 parts to this on my car, the upper part (closer to body of the car) is welded on and is all good to go, now the lower part is seperating from the upper because it has no welds.... would it be ok to just take off the lower cat heat shield part? so that way i still have a shield above the cat inbetween the cat and the body?
thanks for the tips so far
Old 06-20-2006, 06:22 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Re: Heat shield
very common problem for any generation integra. The infamous 3000 rpm heat shield rattle. Most people just remove that section of shield to solve the problem. I had to do mine about 3 years ago. Do a search on here and you'll see tons of threads on this subject.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-21-2006, 03:09 PM
Re: Heat shield
It still wont hurt anything.
The only reason they are on cars is so they wont have lawsuits and wont have to hear bullshit from environment hippies.
1991 Honda Crx Si
Old 06-21-2006, 10:06 PM
ok so i take off the heat shield, and ya with a flat head it was soo poorly welded or rusted threw... whatever... then i start the car up, raddle raddle raddle she still is raddling! so my converter i guess is busted or some crap, so im gona go buy a cat...
thanks for all the help even tho it wasnt the shield in the end lol
Old 07-06-2006, 10:46 PM
steffenst steffenst is offline
Re: Heat shield
I Have Exaust Headers on My Whip And It Dosent Matter If You have a heat shield. Just make sure your fans are working properly. Headers get hot real hot and if you sit in rush hour trafick with your AC on you can burn up your engine real quick. Either way a heat shield is solely manufactured for your saftey so you dont touch the haeaders. And burn the fuck out of your hand. I have done it myself.
