Old 06-19-2006, 03:34 PM
SComp23 SComp23 is offline
Radiator Cap
I figured it would be a good time to replace my cap, it looks like mine may be the original cap which is not good. I have 2 questions though. If my cap isn't giving me problems, should I replace it? Could any "bad" come from replacing it? Also, I went out and bought the Stant cap, however, the "1130?" I believe it is, the replacement number for our Blazers, is rated at 16lb while my stock cap says 15lb, could this cause a potential problem? This cap doesn't have the fancy lever or anything like that, should I get that one? Thanks in advance.
Old 06-19-2006, 06:39 PM
muddog321 muddog321 is offline
AF -Advisor
Re: Radiator Cap
98up # is 11230 and Chevy redesigned their cap cause the original had a smaller center that opened to relieve pressure and then when cool suck coolant back in - they used to clog from the dex cool and stant always used a diff design that Chevy later copied. Forget the lever cause you never have to open it when hot anyway - coolant goes into the reservior. If your mileage is up there then the thermostat should also be changed to avoid possible overheating - another cheap insurance part.
Old 06-19-2006, 07:00 PM
Re: Radiator Cap
Thanks muddog, I will return the cap tonight and get the proper one. As for the thermostat, I just had it replaced about a year ago.
Old 06-19-2006, 07:07 PM
Re: Radiator Cap
Actually I was incorrect, I do have the 11230, but it is a 16lb vs. the 15lb stock cap. Is this a problem?
Old 06-19-2006, 08:59 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Radiator Cap
What you have is fine, the original Chevy cap let in air which cause issues. I have the Stant replacement and do not have an issue at all.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
