Old 06-19-2006, 12:50 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
How would you paint this?
I'm kind of confused on how to do this. How would you paint these parts?
A)
-Prime everything
-Paint black areas first
-Paint red areas
B)
-Prime everything
-Paint red areas first
-Paint black areas
C)
-Prime areas to be red
-Paint red areas
Old 06-19-2006, 12:53 PM
Jay! Jay! is offline
Horizontally Opposed
Re: How would you paint this?
I say "B." It's easier to paint black over red than vice-versa.
Not "C"; try to avoid re-priming between adjacent color coats, because it'll tend to peek through at the edges.
Hierarchy of Subaru:
(Click to see mine!)
Old 06-19-2006, 01:49 PM
M1CRO M1CRO is offline
Send a message via MSN to M1CRO
I'd agree with Fubaz except, It depends how good you can mask off..It might be easier to paint everything red first then mask off and paint black..
If the masking is easy then just paint red first.wait till dry.Then mask and do black.
Then again maybe someone might have done this section already and have an even better Idea...Who knows.
M1CRO.
Old 06-19-2006, 03:29 PM
wouter1981 wouter1981 is offline
Defenatly B
just make sure you're red paint is completly dry and polished out before youi start the black.. and use enamels for the black. If you have some leaks or overspray, you can verry easily correct these things with whitespirit and you wont harm the red (if you've done the red with a laquer based paint)
Old 06-19-2006, 03:53 PM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
I used method A for my Enzo. Just make sure that everything (black) is covered perfectly. But I guess you just have to try what works best for you.
Old 06-19-2006, 03:59 PM
Cold_Fire Cold_Fire is offline
Vendor
B should be the best option.
If you paint red over black it doesn't matter that it looks like that red has covered black completely, you could get some red different from the rest of the parts.
Old 06-19-2006, 04:15 PM
D_LaMz's Avatar
Thanks everyone, looks like I will have to go B and mask off the red with Tamiya tape and paper.
So I will spray a TS-8 then TS-29. Might have to use acrylic black if lacquer is out.
Old 06-19-2006, 05:40 PM
cyberkid's Avatar
cyberkid cyberkid is offline
I used method B when I made my enzo. Not that hard to mask off. Using acrylic black would save you a lot of trouble though. Easier to fix if you mess up.
Here is a post by p-man about the enzo:here and his full WIP thread here. I made the same mistake so .. HTH
Old 06-19-2006, 05:56 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
D)
-Paint black areas
-Paint red areas
-Prime
Just kidding.
I would totally go with B, use laquer red and acrylic black, and not worry much about the red overspraying the first go 'round - you'd rather edges and joints be red than bare plastic, I would assume.
Old 06-19-2006, 06:09 PM
mickbench's Avatar
mickbench mickbench is offline
I'd go with option B. I did something along the same with some bike cowlings. If you use TS for the red, and then use X18 Acrylic from an airbrush for the black, even if you get some overspray, its REALLY easy to clean up. A small bit of water on a toothpick removes some acrylic overspray, and compund does wonders..
Good luck
Old 06-19-2006, 10:34 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Option B
In Progress
Old 06-19-2006, 10:56 PM
D_LaMz's Avatar
Thanks for the input! I'll prime tomorrow and wait 24 hours for it to dry.
Old 06-20-2006, 03:18 AM
Night Stone Night Stone is offline
Send a message via MSN to Night Stone
Option B is the best way as the most of the replies here states.
One rule of thumb to follow for any painter is paint light colors first than dark color. As the dark color will cover the lighter color easily, but a lighter color over a dark color will show bleed thru and may require numerous coats to block the bleed thru.
Old 06-20-2006, 03:41 AM
klutz_100's Avatar
take a look how alex kustov did it here
I think this is what you are talking about - quarter way down on the right side
Old 06-20-2006, 12:52 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
i'd do it B-style.
olly olly oxen free
