Old 06-19-2006, 07:58 AM
LS19962DRBLAZER4X4 LS19962DRBLAZER4X4 is offline
1998 Intrigue Engine Valve Problems
If anyone has any problems with the four door coupe model 1998 Intrigue?
Old 06-19-2006, 10:14 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: 1998 Intrigue Engine Valve Problems
I'm not sure I understand the question. Are you asking if anyone is having problems with the valves on the a '98 Intrigue Sedan 3.8 liter engine? (no Intrigue coupes that I know of).
Typically, these engines don't really have problems with the valves. Intakes and intake gaskets - yes. Also the rear engine crank seal / plate gaskets have a tendency to leak oil. Fuel pressure regualtors are common to go too.
What kind of problems are you having?
Old 06-20-2006, 11:09 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Yeah the 3.8 Series II has a lot of issues with the Upper Intake Manifold, as well as the lower intake gaskets, if you want I can load you up with tons of info on these...
