Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-18-2006, 11:30 PM
lb1159 lb1159 is offline
94 CV smokes
1994 CV doesn't smoke at startup, flooring it on highway,or idling. But after idling for a minute or two you hit the gas to go, you get a puff of blue smoke. This happens at stoplights all the time. It doesn't smoke any other time. Any ideas ?
Old 06-19-2006, 06:27 AM
reekor reekor is offline
Re: 94 CV smokes
What you have is classic dried up valve seals. This is a common problem with 4.6's before the mid 90's. What I have found that really helps in my 92 GM and 94CV is a bottle of "Lucas Heavy-Duty Oil Stabilizer" with every oil change.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-19-2006, 06:28 PM
krewl1 krewl1 is offline
Re: 94 CV smokes
Try some AutoRx. I used it with good results on a few of my cars. You can read about it in the additives forums on bobistheoilguy dot com.
Old 06-19-2006, 09:10 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 94 CV smokes
Yes, valve stem seals are the normal culprit.
I would not worry about it, unless oil consumption becomes an issue.
Old 08-17-2006, 12:22 PM
Bo1118 Bo1118 is offline
Re: 94 CV smokes
i had a 94 CV LX that was smoking the way you described,, put 1 quart of Trans fluid in the motor, ran it for a little while then had the oil changed,, hasnt smoked since.
