Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-18-2006, 08:25 PM
BostonKev BostonKev is offline
Seat Bolts
Hi all, I commonly run into auction cars that have the front seat bolts snapped off from them taking out their equipment. I usually just drill them but it seems like a pain in the butt and I was wondering if anyone had a quicker technique for getting these out. I've lightly tried vise grips and heat (without much luck) but I'll take any suggestions. Thank you
Old 06-19-2006, 06:32 AM
reekor reekor is offline
Re: Seat Bolts
Drill the center of the bolt and use an "easy out" after letting the bolt soak in wd-40 over night.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-19-2006, 09:49 AM
radioman2002 radioman2002 is offline
Re: Seat Bolts
As stated above, otherwise I have had the same problems. Mostly I drill out the center and retap, then I put axle grease on the bolt to keep it from rerusting in.
Old 06-19-2006, 01:00 PM
Re: Seat Bolts
I've found the easy outs don't work that great in the older units but I'll try again in the 2 - 2002's I picked up on Sat. A couple times on the 97's I grabbed at the bolt from under the car and ended up pulling the nut and everything out which made it so I had to throw some large bolts and washers all the way through. Is heat (from underneath) not a good idea? I'm generally pretty good with a torch but I'd have to light the rubber floor or carpet on fire.
Old 06-19-2006, 01:14 PM
Re: Seat Bolts
I'm generally pretty good with a torch but I'd "hate" to light the rubber floor or carpet on fire.
Old 06-19-2006, 10:11 PM
Re: Seat Bolts
Heat works great, but......... You would have to pull back the carpet or rubber mat. Then you will start burning paint and undercoating, it's nothing that you can't spay some rocker guard over once it's done.
Old 06-20-2006, 02:38 AM
KimMG KimMG is offline
AF - Advisor
Re: Seat Bolts
WD-40 is not a good penetrant. Try PB Blaster or something that is designed to penetrate. Let it soak for a couple of days, then use an easy-out.
Old 06-20-2006, 12:04 PM
Re: Seat Bolts
is this something you run into at all W2O? Or would you typically see this when the equipment is removed and say the heck with it?
Old 06-20-2006, 06:11 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Seat Bolts
We have had a few break, but usyally take them out through the bottom as you have said you already tried. You can pull the carpet back and try heat or if you have a torch, not propane, you could melt it out. I don't think the propane will get hot enough to affect the bolt. We sell all our cars as close to proper working order as we can. Hell, we even fill up the tank for the buyer. Have you tried a left handed drill bit? SOmetimes they grab and will break the bolt loose.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-20-2006, 08:12 PM
fleettech fleettech is offline
Re: Seat Bolts
most of the time the reason they break is they are either over tightened or cross threaded have done both myself. what you can also try is welding a nut on the bottom and take it out the bottom.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 06-20-2006, 09:33 PM
Re: Seat Bolts
I'll try the easy outs again. It just seems like I'm running into it more lately. I appreciate all the ideas and I'm glad to see I'm not completely alone on this. Thank you
Old 06-27-2006, 09:47 PM
Re: Seat Bolts
Hi all, just wanted to close this out. I have 2 recent 2002's and tried the pb blaster and the easy outs, no luck. I even bought some new bits and tried drilling them through and it took forever to do 1. I've actually found the quickest and easiest way is to user a hammer and a punch right on top of the broken stud and the 3 tiny tack welds that hold the nut under the car let loose and then you just place a 3/8-2" bolt through with a lock nut and some heavy duty washers on each side and you are good to go. I had all 4 out of 1 car in about 10 minutes. Thanks for all the ideas.
Old 06-28-2006, 06:23 AM
way2old's Avatar
TOKEN HILLBILLY
Re: Seat Bolts
Glad you got it kev. Guess persistance pays off.
