Old 06-18-2006, 04:17 PM
tayl0124 tayl0124 is offline
Need fireing order for 91 3.0 Dohc
if you know the fireing order can you shoot it to me.
Old 06-18-2006, 04:29 PM
Igovert500's Avatar
blue + red light magnet
Re: Need fireing order for 91 3.0 Dohc
The cylinders are numbered from the driver-side (timing belt side) of the engine as 1, 3, and 5 for the front bank, and 2, 4, and 6 for the rear bank. The connections to the ignition coil use the following order, from the front of the car, 6, 3, 2, 5, 4, and 1 (these numbers are stamped on the coil bracket). There are three coils with the following cylinder pairs firing at the same time 1-4, 2-5, 3-6. Firing order is 1, 2, 3, 4, 5, 6. Note that the cylinders numbers are stamped on the coil mounting bracket indicating where the spark plug wires attach.
http://www.stealth316.com/2-sparkchange.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-18-2006, 04:37 PM
Thanks for the quick response
