Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-18-2006, 03:58 PM
95cadiman 95cadiman is offline
Unhappy 95 cadi codes
i read a few post on geting codes i did it and got a few can some one tell me what the r P031 , P048 ,P075 ,P098 ,I039 ,T027 . PLEASE LET ME KNOW SO I CAN GET IT FIXED
Old 06-18-2006, 06:41 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: 95 cadi codes
Go to trouble codes.net, double check the numbers though there may be a 3rd digit missing. The code definitions will be in the list. Fixing theses issues on that car may not be reasonable for a dyer, just don't start putting parts in based on the codes, you will need a shop manual of some kind with a diagnostic trouble tree for these codes, alldata.com is one available on line.
Old 06-19-2006, 06:52 AM
DFBonnett DFBonnett is offline
Re: 95 cadi codes
That's a lot of unrelated codes. When they come up is it noted as HISTORY or CURRENT? Sometimes a bad electrical connection will cause the comp to throw false codes. Try cleaning the battery connections and as many grounds as you can reach. Also inspect the battery cables for any bulges under the insulation which would indicate hidden corrosion. Those two things may solve the problem.
Old 03-19-2007, 08:14 PM
Re: 95 cadi codes
i found out what was wrong the fuel sending unit hose broke replaced it but now my feul gage goes up and down
Old 03-20-2007, 08:02 AM
A990 racer
Re: 95 cadi codes
What was going on for 9 months?
