Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 06-18-2006, 03:18 PM
msaga79 msaga79 is offline
'01 Express 3500 high idle
I have been haing high idle problems for quite a while. I replaced the IAC and TPS and the problem went away. Within 6 months the problem was back and so I replaced the IAC and the problem went away again. Now it is only 4 months later and the idle is back up. Any ideas as to why the IAC keeps going out? I am thinking that there is something else wrong that is wearing it out.
Old 06-20-2006, 02:21 PM
DFBonnett DFBonnett is offline
Re: '01 Express 3500 high idle
Have you looked for any vacuum leaks in the area of the TPS or IAC. Possibly a bad vac hose that you reconnected when working then worked itself loose?
Just a WAG. Possibly an electrical connector that was marginally connected that you bumped and reconnected while working and then worked itself loose again? Have you scanned for codes?
FWIW
YMMV
