Old 06-18-2006, 10:15 AM
Mango™'s Avatar
Mango™ Mango™ is offline
Adjust Idle 91 s-10 4.3
How do I adjust the idle on a 91s-10 4.3 v6. Just install a rebuilt long block and got everything on when I finally got it crankthe idle is way to high. There is a assemble that holds the accelorator and cruise control bale and 1 other cable. Is it possible that was bent? Any can some tellme or show me a pic where the adjustment screw is? The fat chilton does not show me.
Thanks
Mango™
Old 06-18-2006, 08:45 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Adjust Idle 91 s-10 4.3
I adjusted the idel on a full sized 4.3L recently. Sorry no pic's, but here's what I did.
In front of the throttle there was a steel cap in the throttle body (looks like a tiny frost plug on the front drives side on that motor)
I popped that out with a small screw driver, and there was an adjustment screw behind it. I just backed it out and it did the trick.
It's probaby only a 10 min job, and the hardest part was removing the air filter to access it.
Old 06-21-2006, 05:44 PM
RahX RahX is offline
Make sure there aren't any vacuum leaks, the IAC isn't stuck and the TPS isn't out of adjustment.
