Old 06-18-2006, 10:13 AM
mwrobe1's Avatar
mwrobe1 mwrobe1 is offline
'97 Voyager - Hesitation when giving it gas
Hi all. 1997 Voyager, 2.4L, 110k miles.
When giving it more than 1/4 throttle the engine is hesitating. Fuel pump is less than 2 years old, and 2 months ago I changed the plugs and air filter on this vehicle. My teenager brought it home this way with the CEL on...stupid me I didn't use the key shortcut to read it...since the battery cables had some corrosion on them, I cleaned them (thinking that may have been the problem) thus clearing the CEL light. One note though...I never had any exhaust work done on this vehicle. I suspect a clogged cat, since the symtoms are similar to other cars I've owned that needed one.
Will the Autozone service that reads codes read stored codes also? Or should I drive it around awhile and wait for the CEL light to go on and then get the codes read?
**edit** Actually...I never tried the ignition shortcut with this vehicle...my odometer is digital (if it matters)...will the on-off-on-off-on cycle work?
Elwood: It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it.
2013 Chrysler Town & Country Touring
2013 Chevy Impala
2006 Kia Rio LX 80k [SOLD]
1997 Plymouth Voyager 2.4L 180k (headgasket at 75k/tranny at 65k) [SOLD]
Old 06-18-2006, 10:58 AM
vipergg vipergg is offline
Re: '97 Voyager - Hesitation when giving it gas
I would probably wait till came back and get the codes . Catalyst very rarely clog up so I wouldn't lean that way ,could be something like an O2 sensor though. First I would go out and get a good fuel system (not injector) cleaner Techron or Gumout) , get a couple of bottles and run it thru the next couple tanks to rule out dirty fuel system . Also it would be a good idea to clean the throttle body with some good throttle body spray cleaner . Work from there until the codes show up again . The keydance method of getting codes should work fine on that era.
Old 06-22-2006, 05:54 AM
mwrobe1's Avatar
Just an update...I never did get the CEL light to show up again. However...I had changed the plugs on my van over a month ago and never changed the wires. I slapped a new set of wires on there and now she runs like a champ. The resistance on the old ones (2 years old) must have been really bad!
Jake: Hit it.
2013 Chevy Impala
