76 compared to a 79 confusion
ok here is what i got...if the 76 has more bhp and is 100 pounds lighter why does it say that my hp to pound ratio is 15.9 but the 76 is only 9.1 ? eh im confused again.. typo or am i just an idiot..or maybe both lol and do these stats sound right to you guys?
1979 Pontiac Trans Am Year 1979 Make Pontiac Model Trans Am Engine Location Front Drive Type Rear Wheel Weight 3500 lbs | 1587.6 kg Performance Top Speed 190 km/h | 118.1 mph Similar top speeds Engine Engine Configuration V Cylinders 8 Aspiration/Induction Normal Displacement 6555.00 cc | 400 cu in. | 6.6 L. Valves 16 valves. 2 valves per cylinder. Valvetrain OHV Horsepower 220.00 BHP (161.9 KW) @ 4000.00 RPM Torque 320.00 Ft-Lbs (433.9 NM) @ 2800.00 RPM HP to Weight Ratio 15.9 LB / HP (Vehicles with similar ratio) HP / Liter 33.3 BHP / Liter Bore 4.12 in | 104.6 mm. Stroke 3.75 in | 95.3 mm. Compression Ratio 8.1:1 Vehicles with similar horsepower and weight Transmission Information Gears 4 Transmission Manual Final Drive 3.23:1 Dimensions Seating Capacity 4 Exterior Length 198.101 in | 5031.8 mm. Width 73.001 in | 1854.2 mm. Height 49.301 in | 1252.2 mm. Wheelbase 108.201 in | 2748.3 mm. Front Track 61.301 in | 1557 mm. Rear Track 60.001 in | 1524 mm. Ground Clearance 4.611 in | 117.1 mm. Vehicles with similar dimensions Steering Recirculating Ball with Power Assist Brakes Front Brake Size 279.001 mm | 11 in. Tires / Wheels Tires Front : P225/70 R 15 Rear : P225/70 R 15 1976 Pontiac Trans Am Year 1976 Make Pontiac Model Trans Am Engine Location Front Drive Type Rear Wheel Weight 3400 lbs | 1542.2 kg Performance 1/4 Mile 12.05 seconds. Engine Engine Configuration V Cylinders 8 Aspiration/Induction Normal Displacement 400.00 CU IN. | 6556 cc. | 6.6 L. Valves 16 valves. 2 valves per cylinder. Valvetrain OHV Horsepower 375.00 HP (276 KW) Torque 320.00 Ft-Lbs (433.9 NM) @ 2800.00 RPM HP to Weight Ratio 9.1 LB / HP (Vehicles with similar ratio) HP / Liter 56.8 BHP / Liter Bore 4.10 in | 104.1 mm. Stroke 3.75 in | 95.3 mm. Compression Ratio 8.1:1 Vehicles with similar horsepower and weight Transmission Information Gears 4 Transmission Manual Final Drive 3.23:1 Dimensions Exterior Length 198.101 in | 5031.8 mm. Width 73.001 in | 1854.2 mm. Height 49.301 in | 1252.2 mm. Wheelbase 108.201 in | 2748.3 mm. Rear Track 60.001 in | 1524 mm. Ground Clearance 4.601 in | 116.9 mm. Vehicles with similar dimensions Steering Recirculating Ball with Power Assist Brakes Front Brake Size 280.001 mm | 11 in.
Re: 76 compared to a 79 confusion
whered u get those stats on the 76.?
hehe i think you got it mixed up dude, its lbs to horsepower. not horsepower to lbs, so the smaller number you got, the faster your car is.. (supposedly)..
and yeah! whered you get those stats from? they're pretty sweet! i want my stats... 97 SS camaro..
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
i belive this is your car
and how can the 79 and 76 camaro be lighter than my 97?!?! mine is 3800 lbs.. how the heck. i thought cars 'in those days' were buit friggin heavy!
that 76 is highly modded... from the factory the 76 with the 400 cid engine is rated at 185 hp and 215 ft.lbs... these numbers are slightly underated but bu no mean were 76's rollin off the line with 300+ hp in 76
ohh. nice. that explains it...
http://www.conceptcarz.com/vehicle/z...arID=171#stats
yeea my stock 76 is gutless.. she sounds hot but its a 3800 pound tank that looks fast
haha yea i guess its got a few things goin for it
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
