Old 06-18-2006, 01:17 AM
Im3good4u's Avatar
Im3good4u Im3good4u is offline
Dam Headlights!!!
Hey guys i've been gone for a while because i was on vacation...anyway...
My car was having the dreaded headlight motor problem and just ordered a new motor got back in town excited to close the eyes and it did not work. There must be a relay or a switch so im wondering if anyone knows were it is located.
ONe goes up and down like everything is fine but the other does not attempt to spin the motor.
1998 Trans Am Bone Stock...For Now!
Sold 2004 Dodge Ram 1500 QC Hemi W/ K&N Air Filter, Superchips Tuner.
Sold 1994 Firebird Formula W/ Hooker Headers, Magnaflow Exhaust, Ram Air, Fuel Pressure Regulator.
Quiters don't win, Winners don't Quit.
Old 06-18-2006, 02:58 PM
Im3good4u's Avatar
Re: Dam Headlights!!!
any help would useful guys...
Old 06-18-2006, 05:21 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
ill try to help you altough my car doesnt have them but i belive there are plastic gears that sometimes wear out have you checked them? im sure if you replaced the motor yo udid but just trying to give you any help i can. also when you turn on your headlights does the side that doesnt lift make any noise?
Old 06-19-2006, 12:00 AM
Im3good4u's Avatar
no there is no noise wich means that the motor is not turning or attempting to turn
Old 06-19-2006, 12:08 AM
79Bandit's Avatar
have you checked the fuses? im not familiar with that year as i said but is there only one fuse for both lights or two i know this may sound crappy but im trying to help you out the best i can because no one else has any ideas
Old 06-19-2006, 04:21 PM
buck6680's Avatar
buck6680 buck6680 is offline
Before doing anything else, check the plug connections between the chassis harness and the headlight assembly. I have seen several of those get coroded and not work.
If that's not it, check to see if you have both battery voltage and ground coming into the motor connector, if not, then it could be the headlight controller. Its a 5 - 6 inch square black box, mounted behind the drivers side headlight assembly inside the engine compartment. Should have two plug connectors attached to it.
Good luck,
Old 06-21-2006, 09:20 AM
Im3good4u's Avatar
Alright man thanx alot... I havent gotten to it yet but tomm im changing my oil and hoping i can fix that
Old 07-03-2006, 09:19 AM
Im3good4u's Avatar
I did not find any corroded cables everything looks as if it was in good shape.
About this contorller first of all i cant find it because im not sure where it is and there really isnt anything behind the headlight did u mean behing and under ?
Dont the headlights share controllers because one of my headlights is working fine?
Is there a relay swicth anywere?
By the way there is power at the plug that connects to the headlight i checked it with a fuse tester?
Old 07-03-2006, 02:55 PM
gmack221's Avatar
gmack221 gmack221 is offline
The plug buck6680 was refering to is the one that connects to the headlight motor, not the headlight bulb ... just to make sure thats cleared up.
As for your problem, check the voltage at the motor plug, make sure its there when it should be, if it is then you probably got a bad motor, if you don't have voltage i'd trace those wires and clean all connections .... seems like they should use one control module (but I don't know for sure). test your motor by plugging it into the other side (yeah its a lot of work to tear apart both sides, but its worth it to know for sure ....
If you have gears strip out i'd replace them with these gears http://my.execpc.com/C4/4A/rodney1/firebird/
I put them in mine and everything is good now, the only problem I had was the cover poping back off after I glued them back on, small home made bracket to hold the cover on and were back in business though.
If your motor is bad and the new one isn't guarenteed ... like if you got an e-bay motor ... and the old motor is good just has a stripped gear ... combine the two to make one good motor, the motor comes off just like a power window motor. hope you get it all figured out!
Old 07-05-2006, 02:34 PM
Im3good4u's Avatar
alright there is volatage at the plug but the motor is not spinning and when i plug into the other side it does spin...
This module thing or controller are they independent(one for each side)?
Were are these module/controller and what do they look like?
