Old 06-17-2006, 09:00 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
intake manifold
i want to upgrade my intake manifold. i'm thinking of the trickflow street heat intake, would the 70 mm throttle body be to big. i am doing a mass air swap now and after the summer heads and a cam. would there be a better choice that would enhance a stock motor?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 06-18-2006, 12:40 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: intake manifold
I've heard some really good things about the Holley EFI intake. It would be cheaper for you to buy a H/C/I kit from Trick Flow or Holley. Thats what I would suggest and also what I would do if I had a stock 5.0 car.
1969 Cougar
357w & TKO - 475hp
