Old 06-17-2006, 05:05 PM
ajamato86 ajamato86 is offline
Send a message via AIM to ajamato86
transmission removal
i have a 98 2.2 5 spd, and am removing the tranny to replace the clutch
i have all the bolts off, all wireing and fuel lines off, and the shifter, crossmember, and driveshaft out. i seperated it from the motor about a half an inch, but it doesnt want to move any further. any ideas as to what to do?
foxtrot delta lima
Old 06-17-2006, 09:32 PM
Techyon Techyon is offline
Send a message via AIM to Techyon Send a message via Yahoo to Techyon
Re: transmission removal
you NEED to make sure that when removing the transmission that you do it STRAIGHT!
if you tweak the input shaft in any way it will never be correct and it will destroy your front bearing in your transmission.
Removing the transmission and installation is rather tight. I had to wiggle mine back and forth gently to remove it and install it.
Hope this info helped.
http://clanmage.net/~techyon/Techs_Garage/
1984 GMC S15 Soon to be a
SS-10 "my own creation"
383 Stroker, World Products Heads, 850cfm double pumper
1984 GMC S15
1987 Jeep Cherokee Pioneer
1989 Chevy S10 4.3ltr with 10" of lift "Stomper"
1991 Chevy Cavalier euro
2001 Dodge Ram 2500 Cummins Turbo Diesel
For Sale:
1976 Pa Custom speed boat
19' Fiberglass Deep Hull "Runabout"
Asking 3000.00 OBO
Old 06-18-2006, 08:52 PM
OverBoardProject OverBoardProject is offline
Banned
Look under the hood and see what's stoping the motor from tilting. The fan or anything might be catching.
Once the motor tilts far enough the transmission should slide prettty easily.
Worst case senerio you'll have to hang the motor (as a safety precaution, plus easier to raise later) and remove the motor mounts. This will allow the motor to drop a fair amount giving you oddles of room
They're pretty tough units, so unless you did something stupid you shouldn't have to worry about the input shaft.
Old 06-18-2006, 09:00 PM
my motor is tilting fine, but im taking it out straight, like the manual says. do i have to take it out on an angle?...am i missing something.
i hear these are pretty tough to take out, but this is rediculous, its as if the tranny is welded to the damn motor.
foxtrot delta lima
Old 06-18-2006, 10:57 PM
is it nessecary to remove the dust sheild to remove the tranny...could that be what its stuck on?
foxtrot delta lima
Old 06-18-2006, 11:46 PM
Banned
I've always removed the dust sheild, and would never try without it.
You should be able to see or feel what's left connected, or more than likely what it's hitting.
I also always tilt the motor, and have never had too bad of a problem on a 2wd.
The 4x4's on the other hand are tough, and your better off pulling the motor.
It doesn't have to tilt much, just around 15 degrees usually
If you can seperate the bellhousing from the transmission on your model it might make the job easier. It's usually the bellhousing that seems to catch everything
Good luck with it, and wish that I could help more
