Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-17-2006, 01:09 PM
Carfreak18's Avatar
Carfreak18 Carfreak18 is offline
Send a message via AIM to Carfreak18
Camber in front right tire
alright i need to put camber in my race car becuase i keep blowing up my front right..how do u do camber?..do you drill holes into the strut?..
Holland Speedway
Lake Erie Speedway
Tioga Speedway (R.I.P)
Wyoming County Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Many more to come....
Old 06-17-2006, 05:18 PM
Carbon Fibre's Avatar
Carbon Fibre Carbon Fibre is offline
Re: Camber in front right tire
No holes in strut! Your dillema would be better recified with a F-body chassis brace. It will tie the front and rear sub-frames in the unibody together, resulting in less torsional twisting in the car. In higher power 'stangs with good grip (10" slicks, slapper bars) twist in the car puts alot of lateral -sideways- force on the front tires, which could be scrubbing them to death. If yer using drag shocks in front, the front wheels droop, accentuating this. I would't worry about yer camber. There's probably some negative camber built in, which is fine for a drag car.
Good luck!!
The Builder
Old 06-18-2006, 12:43 AM
Carfreak18's Avatar
Sorry, i shoulda been more specific, i race a weekly circle asphalt track, i have a 3.1 liter V6 cutlass supreme 92'..maybe that helps
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-18-2006, 12:46 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
If the tire is accually going flat, your camber isnt the issue.. your tire is rubbing something.
Old 06-18-2006, 09:02 PM
Carfreak18's Avatar
My tire isnt just going flat,it is blowing right up from the stress through the turns and plus i already cut the wheel well to give the wheel more room to move
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-18-2006, 09:22 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
then camber probably wont change it much if you're putting too much stress on it. get better tyres.
Seatbelts Saved My Life
Old 06-18-2006, 09:54 PM
Carfreak18's Avatar
Well I wouldnt say its the tires,the damn thing blew up in 20 laps and it was barely used. This class you use stock tires also
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-18-2006, 09:58 PM
then it's not wear. if they're stock tyres they're propbably not designed to be put through 20 laps of hard cornering. it could be that the car's too heavy for that tyre and that stress level.
Old 06-18-2006, 10:00 PM
Forunn Daberator
Camber will acually put more stress on the tire. Get better tires like the drunken englishman suggested.
Old 06-18-2006, 10:08 PM
Carfreak18's Avatar
well im running a 15" 205 i think, what do u suggest?
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-18-2006, 10:12 PM
Forunn Daberator
Well that doesnt really tell us anything, thats not even a complete measurement...
Old 06-18-2006, 11:23 PM
kevinthenerd kevinthenerd is offline
It still may not be enough room. Make sure it has enough room to move at both full turning lock and at full suspension travel.
Old 06-18-2006, 11:25 PM
what profile? High profile tires will cause more sidewall flexure which could lead to problems (but low profile tires aren't the gods of cornering people make them out to be either)
Old 06-19-2006, 12:38 PM
Carfreak18's Avatar
Alright thanks for all the info
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 06-19-2006, 10:59 PM
actually, i don't drink.
Closed Thread
