Old 06-16-2006, 11:57 PM
shizznizz980 shizznizz980 is offline
Send a message via AIM to shizznizz980
Question Wireless Network Laptop question
ok, I have a laptop that has a wireless card on it and it also has the ethernet port its the only computer in the house. Ok so my question was if I get sprint dsl internet and a belkin wireless g router, And when I set up the router I connect it to the dsl modem and then the laptop through the ethernet port and once everything is good on the wired part and I can go on the internet while im wired to the router and modem but if I disconnect the laptop from the router and try to use the wireless card can I still get online even though there isn't a computer at the router wired? Or would I have to go with cable internet?
Old 06-17-2006, 12:34 AM
Damien's Avatar
Damien Damien is offline
Send a message via AIM to Damien Send a message via MSN to Damien
Re: Wireless Network Laptop question
wow i got lose. hook your modem to the router. there should be a slot with "cable" or "internet" above it. then, get another ethernet cable and plug that into one of, normally 4, slots and that goes into your comp. then whenever you unplug it and switch to wireless, your router will be receiving the internet from the modem.
as for everything else on the router and setting it up. read the maual very carefully or not, but do follow it. it's easy and simple so there shouldnt be too much difficulty.
Old 06-17-2006, 02:34 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Your internet connection comes from your ADSL Modem, to your Wireless Router which then splits it up and sends it to your network connections - wired and wireless. It doesn't matter if you have a computer connected to a wired port on it or not, as long as it is setup correctly, as most routers don't allow you to configure them wirelessly.
Cable internet has nothing to do with it, except a different type of modem, maybe do it if it's a better deal where you live?
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 06-17-2006, 10:33 AM
Mr Wiggl3s Mr Wiggl3s is offline
Banned
Send a message via AIM to Mr Wiggl3s
I got lost at plugging wireless in
