Old 06-16-2006, 10:50 PM
Weasel14242 Weasel14242 is offline
Question 95 Ford Escort Thermostat
I have a 95 ford escort. The thermostat guage in the car is not working properly. When I shift gears I notice that it moves as well and then it moves back down to the C, where it is not displaying the temperature. Could this be caused because the thermostat needs to be changed or is it possible it is something else? I am not sure if there is a sensor involved that could be broken. Any ideas?
Thanks
Old 06-16-2006, 11:31 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 95 Ford Escort Thermostat
Ahhhh... the classic overcooling problem.
Search this forum for "overcooling" and you will find a wealth of info.
In short... consider these:
1. Thermostat
2. Temp sensor (there are two... the one you should be conserned with is the second one in the the hose when moving toward the firewall from the thermostat).
3. The thermostat housing. (To save some time, should you need this it costs about $40 and is listed as a "water outlet" at most of the parts stores).
Old 06-17-2006, 06:26 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Red arrow is temp sending unit.
