Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-16-2006, 04:38 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
fuel cut?
(Ok I know we shouldnt be racing around, but sometimes i just feel the need.) ANYWAYS whenever I really get on it, it starts cutting out or something at 3/4 throttle - Wide Open Throttle. when it cuts out it sounds like something is slipping or something, or like a hose blew and its shooting out a lot of air or something, hard to explain. If I let off the gas though and then press back down, it stops and drives normal and pulls hard again, and then as the RPMs get up cuts out again. I think its fuel cut, but not positive. Any ideas as to what it is and how to fix it?
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 06-16-2006, 08:07 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: fuel cut?
Sounds more like a boost leak to me, but I don't own a turbo car so who knows. Do a boost leak test anyway just to make sure.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-16-2006, 09:11 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: fuel cut?
how much boost are you running? I think it's either a spark issue (replace plugs and wires) or its a tune issue, you shouldn't be running more than stock boost until you get injectors, so what are you running?
now - 2000 civic
soon - 2002 is300
Old 06-16-2006, 10:06 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: fuel cut?
Most likely a boost leak since your hearing that noise. Do a test
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-17-2006, 10:54 AM
Re: fuel cut?
stock injectors. 12-16 psi. i was looking at some greddy 660cc injectors on ebay for $400, and pte precision 880cc injectors for $259. Does that sound like they would be big enough? Also, (I know this is gonna sound dumb) I have a safc hooked up and like a putz i dont know how to tune it for crap, could it be tuned wrong, and thats the reason for the fuel cut, if it actually IS fuel cut? Could it also be my wastegate opening? I'll look around for a boost leak. Just to be sure, where are all the places that a boost leak could happen? should I just follow all the hoses that have to do with turbo, air filter to turbo, turbo to intercooler, intercooler to throttle body, and the boost solenoid hoses, and thats it or are there more spots to check? thank you all very much!
eclipsed @ 3am
Old 06-17-2006, 01:07 PM
blk_srt's Avatar
Re: fuel cut?
check out www.vfaq.com and look up how to do a boost leak test
Mods:
Old 06-17-2006, 03:13 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: fuel cut?
http://www.vfaq.com/mods/ICtester.html there you go. I made one a while ago. Very easy to make and a very good thing to have layin around.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 06-17-2006, 03:15 PM
Re: fuel cut?
awesome i was just looking around vfaq right now and i couldnt find that tutorial. thanks man
eclipsed @ 3am
