Old 06-16-2006, 04:20 PM
Katsura Katsura is offline
DIY Paint Booth with SHower extraction fan
Sorry about the number of questions asked recently! I'm really getting into modelling and needs lots of advice, thanks for all your great tips.
Today I went to B&Q and an idea came up about construting a DIY paint booth with extraction fan.
I'm thinking about getting a big plastic crate (those type you stire misc stuff), which is smooth and flat on the inside walls.
I'll then drill a hole in it, and connect a IY shower extraction fan to it - the one I saw came with an induction port, flexi tube (extendable), the fan and extraction port.
The output is something like 180m/3 air flow. Is this enough and would this project be dangerous? ie, extracting flammable fume towards an electric motor not protected?
Do I need to add some kind of foam in between the duct and the fan?
Please let me know if this will be safe enough, if it's not then I'll abandon the idea.
Thanks.
Old 06-16-2006, 04:55 PM
freakray freakray is offline
AF Modelrater
Re: DIY Paint Booth with SHower extraction fan
If you're spraying paint you need to have an explosion proof fan to be completely safe, with open brush motors, there is a risk of fume ignition due to the sparks created by the motors.
Bathroom fans are no explosion proof so you create a risk in using them, I recommend looking for another alternative.
AF User Guidelines
Old 06-18-2006, 09:00 PM
mbwoods mbwoods is offline
bathroom fans have to be sealed as it wouldnt have to be affected by moisture and condensation, so i think they would be fine
Old 06-18-2006, 09:02 PM
AF Modelrater
Bathroom fans are not explosion proof. They may withstand some non-flammable moisture, but as far as being non-sparking (i.e brushless motors) they are not classed as explosion proof.
AF User Guidelines
Old 06-18-2006, 09:03 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
what fans are? are they specifically labeled explosion proof?
Seatbelts Saved My Life
Old 06-18-2006, 09:07 PM
AF Modelrater
Yes. In the UK you can look for EX classed motors on fans. Brushless fan motors are explosion proof by design.
The ideal fan type for a spray booth is one like this:
Note how the motor is totally separated from the area where the gas will flow.
AF User Guidelines
Old 06-18-2006, 11:16 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
you could use a couple computer case fans, those are brushless.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-19-2006, 06:45 AM
AF Modelrater
The big 6" brushless panel fans are better, can be had for reasobably cheap too from panel suppliers.
AF User Guidelines
Old 06-19-2006, 07:40 AM
Thanks everyone.
Freakray: where in the UK can I get fans like the ones you shown?
Are they specialist suppliers?
