Old 06-16-2006, 03:55 PM
speener's Avatar
speener speener is offline
Headlight Trouble
Whenever i attempt to glue headlights on a car i always seem to leave alittle glue resiude underneath it and it looks bad. I try to use the littleest amount of glue on the outer edge and carefully put it in place but i can always see glue marks. Any tips or tricks to get headlights looking mint? Thanks
Old 06-16-2006, 04:01 PM
wouter1981 wouter1981 is offline
Re: Headlight Trouble
what gleu do you use? Don't use plastic gleu or supergleu (cyano acylic), use white gleu. It dries completly transparant and you can easily fix mistakes with some water. 2 components works also and is verry strong, but you white gleu is THE way to go in my opinion
Old 06-16-2006, 05:31 PM
DasWiesel's Avatar
DasWiesel DasWiesel is offline
Some clear paint is another simple way to glue them without any damage.
Julian
Old 06-16-2006, 06:07 PM
speener's Avatar
i use the liquid tamiya stuff, looks like water. White glue like i used to use in art class at school??/ or is there another product i could buy
Old 06-16-2006, 06:20 PM
freakray freakray is offline
AF Modelrater
White glue like you used in art class....yes.
AF User Guidelines
Old 06-16-2006, 06:28 PM
cyberkid's Avatar
cyberkid cyberkid is offline
The liquid tamiya stuff is extra thin liquid cement. Tamiya has a nice white glue called 'water-based type craft bond', but basically its the same as the stuff you use in art class. 1 point though, even though it dries clear, try to use as less as possible.
Another alternative is like when DasWiesel said, clear paint.
Old 06-16-2006, 06:32 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
tried lately to use white glue, works for me.
olly olly oxen free
Old 06-16-2006, 06:39 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
I used to do that a lot when I was younger. I've learned that what works the best for me is if you put a small amount on a toothpick, and then just put small drops of glue around the body of the car, then place the headlight on the glue.
Old 06-16-2006, 07:01 PM
M1CRO M1CRO is offline
Send a message via MSN to M1CRO
speener, I used to have the exact same problem..I solved this in two ways.
Firstly I almost always make an outline around the glass lenscover with a permanent marker.This makes for a realistic rubber seal around the lens, Also it gives u a little area around the whole light in which to paint on some pva{White} glue.Which you can water down a little so it will flow better.Even white wood glue works.
Use a small stick with some blu-tac or plasticine to hold the lens while you work.From the outside. This gives you more chance to get a perfect finish.Also when the glu has slightly set, You can use the stick to position the lens into place without fear of touching the glue..
Hope this helps.
M1CRO.
Old 06-17-2006, 02:03 PM
speener's Avatar
Nice ideas guys can't wait to try them out on my next model. Just finishing up an rx 7 now i think i am going to go old school maybe an impala ss or a mustang. The current rx7 i had trouble in the paint booth. First i tried painting it white but it was not covering the black plastic. Then i realized i needed to prime it so i decided to paint it blue but the blue was not covering it well either so i masked so graphics on the car and painted it black. I used a yr old can of testors and the paint job is sort of lumpy not bad but not smooth and shiny like my other cars painted with tamiya. One more part must be painted and mounted then it will be done. The lights are small so the mistakes there are hardly noticable. I am happy with it but it has been frustrating. I don't have a url of my photos so i cannot show u any sorry.
