Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-16-2006, 03:32 PM
MikeSeq MikeSeq is offline
Programming Instructions for Remote
Looking for instructions on programming 2nd remote for '93 Buick Pk Ave Ultra. Any help out there?
Thanks.
Mike
Old 06-16-2006, 05:54 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Programming Instructions for Remote
Mike, welcome to Automotive Forums. Fortunately, your car is quite simple to program. Jump the (ALDL) Assembly Line Diagnostic Link. You will find this connector under the driver side dash, but you will have to look through a square cut out in the panel to see the connector, it is recessed behind that panel, almost directly under the steering column.
Jumper pin A to pin G with a fused jumper (3A)
Doors will lock and unlock
Press the UNLOCK button on the remote
Doors should lock and unlock again
if you have more remotes press their unlock button (up to 4)
remove jumper wire
________|________
[F] [E] [D] [C] [b] [A]
[G] [H] [J] [K] [L] [M]
Old 06-16-2006, 06:00 PM
Thanks so much for your help!
Old 06-24-2006, 02:01 PM
shawoli shawoli is offline
Hi! Acquired a second hand 1992 PA, but the previous driver lost the remote. I queried the local GM dealer, and he confirmed that the Buick came out of factory with a built-in keyless system. So I bought a remote, but can't get the vehicule into programming mode.
When I jump pin A and G (DLC is 12 pins), nothing happens (no lock - unlock of doors). Pin G has a metal connector (as it should), and I can do the ECM testing by jumping A and B pins (so not a A pin problem or jumper problem). I tried both as the car manual says (removing the keys from the ignition), and the procedure which came with the remote says (leaving the keys in the OFF position).
Would anyone have an idea (some fuse somewhere?, a missing part?).
Thanx
Old 06-28-2006, 02:33 PM
HotZ28's Avatar
AF Moderator Elite
Lightbulb Re: Programming Instructions for Remote
Shawoli, welcome to AF!
I was just wondering if the dealer checked your VIN # or RPO codes to see if your car actually came from the factory with keyless entry, or did they just confirm that was an option in 1992? If you will notice the below “installment rate” of different options in the 92, that only 55% of the PA's had keyless entry installed! Could yours be one of the 45% that did not have this option?
1992 Model Year
Installment Rate
Engine:
3.8-liter V-6: 93%
3.8-liter supercharged: 7%
Traction Control: 6%
Leather Seats: NA%
Keyless entry: 55%
Here is how to check to see if your car came with the option; RPO codes can be found in the trunk area of most GM cars. Yours is located on the cover for the spare tire. Look for RPO (AU0) = LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (See pic below for example)
Old 06-28-2006, 05:22 PM
Hi HotZ28.
The dealer told me he used the VIN () to check if the PA is equipped.
I tried to locate the RPO codes on the spare tire code, but could find nothing (except a notice explaining how to change tires). Could the RPO be possibly placed somewhere else (my car was sold by GM in Switzerland, so might have been produced out of the States (possibly Canada or Israel), though I don't know if this makes any difference)?
Cheers!
Old 06-28-2006, 06:19 PM
HotZ28's Avatar
AF Moderator Elite
Unhappy Re: Programming Instructions for Remote
Look in the glove box, or under the center console lid. It has to be somewhere, unless it was removed!
Old 07-07-2006, 09:27 PM
Garfield2's Avatar
Garfield2 Garfield2 is offline
Any good diagrams of the Buick Park Avenue 1996 for jumpers? I have just bought a used '96 Park Avenue and things work all very well. I have 2 remotes from my 93 Buick Ultra and was wondering about trying to program them to this car.
Also the vents don't blow air, just the above dash and on the floor. Even if I put it in "Mid - Floor" mode I don't get air comming out of the vents. hmmm
Vern
3 out of 2 people don't fully understand fractions!
http://vernsdidj.com didgeridoo stuff with pictures of a Baldwin B50 bypass filter on a 96 Buick PA.
Old 07-20-2006, 10:37 PM
TTL_DNS TTL_DNS is offline
does that diagram work for 94 park avenue
Old 11-16-2006, 12:10 AM
MWW MWW is offline
Ssame problem on my 92, turned out to be the vacuum reservoir on the firewall. The vacuum supply from the intake manifold came loose, so the vacuum solenoids would not operate. The vac line is a plastic line, there is a flexible rubber coupling to connect to the reservoir. Good luck.
Old 11-16-2006, 09:31 AM
HotZ28's Avatar
AF Moderator Elite
Posting in Closed or Outdated Threads
opcorn:
Closed Thread
