Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-16-2006, 04:18 PM
talontsi26 talontsi26 is offline
smog with a bad turbo!!!!
I have to smog my car to remew my tags, but my stock turbo is almost dead. It burns oil like crazy and has really bad shaft play. The turbo wont boost past 6 psi and I can get about 2 psi of max boost in first gear. My question is, is it possible to pass smog with a bad turbo or should I just buy a new turbo??
Old 06-16-2006, 04:48 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: smog with a bad turbo!!!!
It seems you are unable to recieve both e-mails and PMs for some reason, so I'm posting this here.
Please read:
http://www.automotiveforums.com/vbul...d.php?t=575394
And also put the year, make and model of your vehicle(s) in your sig, along with any modifications you have done to it.
Thanks.
-shpyder
The daily driver. The weekend cruiser. The lazy shop hog.
Old 06-16-2006, 04:50 PM
Shpyder's Avatar
Moderate moderator
Regarding your post, I think you might fail emissions, since the burning oil coming out your tailpipes may contain more HCs and NOX than usual, though I don't know exactly what the burnt oil content separates as in terms of percentages. If you need a new turbo anyway, just get a replacement and then smog it.
Old 06-18-2006, 04:26 PM
I just put a freshly rebuilt 13g in my car, is it possible to pass with this turbo?
93 talon tsi awd
-2.5' turbo back exhaust
-k\n filter
-uicp
-balance shafts removed
Old 06-18-2006, 07:46 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
93 talon tsi awd
-k\n filter
-uicp
Why wouldn't it be?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-03-2006, 12:00 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
In most states you will fail for visible smoke. I know in Colorado they will run the test to make sure the #'s are good, but will fail for the smoke. Good luck
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
