Old 06-16-2006, 01:02 PM
mountie1982's Avatar
mountie1982 mountie1982 is offline
1997 Blazer 4.3 Running Rich
I just changed the plugs in my 97 blazer 4x4 4.3L. After a realy long painful time I got them out. All the plugs are equaly fouled up the same with carbon. Lots and lots of carbon. I was told this is due to running to rich. I have little experiance with this type of problem. Any ideas on what I can do to level this out? I searched and found a thead about a nut kit. What is a nut kit and what does it do?
2006 Dodge Ram 1500 Quad
Why Dodge it when you can RAM IT?
1964 Vw Baja 1600
Old 06-16-2006, 01:39 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1997 Blazer 4.3 Running Rich
Was the carbon black or white?
What brand of plugs are you using.
97 W engine does not use the nut kit set up.
Fuel lines go in the top. The older type with the fuel lines going into the rear use the nut an fuel line kit to get the fuel in and out of the plamtuim or injector unit.
Any black smoke or check engine lights? Is the engine running good?
MT
MT
Old 06-16-2006, 01:44 PM
MT
Ac delco plugs. Black smoke only on heavy accel. engine runs good now. It started running real rough at idel but it great now the plugs are new. This is a rebuilt engine maybe 35000 k Carbon was white
1964 Vw Baja 1600
Old 06-16-2006, 01:59 PM
MT-2500's Avatar
AF - Advisor
Some White carbon is normal
Give it a little time and see if black smoke on accel clears up.
If not you may need to check things over.
Good luck
MT
MT
Old 06-16-2006, 05:10 PM
Good luck
MT
Some is normal but what about a lot. I wish I had picutres. If the smoke doesnt go away what things should I start to check out. Internal engine parts or sensors type things?
1964 Vw Baja 1600
Old 06-16-2006, 07:49 PM
MT-2500's Avatar
AF - Advisor
If it keeps on putting out black smoke look at fuel pressure and pcm/vcm controls and sensors.
One thing to look at is the fuel trim readings on a scanner.
If it is very bad it should be setting a code someplace.
let us know how it goes.
MT
MT
Old 06-16-2006, 10:25 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Has any other tuneup item been replaced?
PCV valve?
Air filter?
Cap and Rotor?
MAF Cleaning?
Also, how many miles on the engine?
Has the ignition switch ever been replaced?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-17-2006, 04:23 PM
PCV valve?
Air filter?
Cap and Rotor?
MAF Cleaning?
PVC valve I have never changed in in the year and bit I have owned it. Air filter cap rotor were changed. I havent did a MAF cleaning. Ignation switch was replaced a few months back. Engine rebuilt about 35000km ago.
1964 Vw Baja 1600
Old 06-17-2006, 10:07 PM
BlazerLT's Avatar
AF -Advisor
Ok, the eninge was rebuilt 35,000kms ago, but what about the O2 sensors, how many miles on them?
Old 06-22-2006, 06:12 AM
Changed them just after the engine swap. It seems to be all good now. So I dont know what it was. O do have a new problem but i gonna start a new post for that.
1964 Vw Baja 1600
Old 06-22-2006, 12:19 PM
BlazerLT's Avatar
AF -Advisor
Could have been a bad batch of gas.
I suggest running a full bottle of Redline SI-1 Complete Fuel System Cleaner in your next tank of gas.
It is supported by BMW, Chev, Toyaota and Honda and it is one of the best Fuel Injection cleaners on the market.
I am using it right now and what a difference.
Old 06-22-2006, 08:30 PM
Yea must have been. I used a injector cleaner about 1000km ago now. Cant think what brand I used. It was in a purple bottle. Engine runs way smoother and no smoke.
1964 Vw Baja 1600
