Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-16-2006, 09:10 AM
Brian_D Brian_D is offline
Upper Control Arm Bushings
Have a '97 AWD and replacing the upper control arm bushings with Energy Suspension. Energy Suspension only provides the poly shells for the upper bushings and the sleaves (?) from the old bushing need to be reused. Problem: appears the factory sleaves do not seperate for bushing removal/replacement without self destructing. Anyone else have this issue when replacing their upper control arm bushings?
I hate to lay more $$ out for a quality (?) part that I've already purchased.
thanks
Old 06-16-2006, 09:26 AM
hunter01 hunter01 is offline
Re: Upper Control Arm Bushings
Have you tried to heat the sleaves with a torch and chisel out the old bushing?
Old 06-16-2006, 09:46 AM
Wish I had a picture to show, but appears the factory outer shells are formed as one piece and when attempting to remove either end of the shell, the entire shell is damaged beyond reuse.
Old 06-16-2006, 10:35 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
May I ask why you are replacing them?
If your front end is clunking, check out this thread.
http://www.automotiveforums.com/vbul...d.php?t=302656
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-17-2006, 09:47 AM
Markgc's Avatar
Markgc Markgc is offline
That doesn't sound like a very viable part.
I imagine that the only way to get them out is to burn them out. I would put the oxy torch on them and burn out the rubber. I used to do that with undershield before welding cars in the good old days in the UK. When the part cools down the remainder of the rubber might well be brittle enough to clean it all out. Pressing the new rubber part into that old metal sleeve may well present you with another problem. People use hair lacquer as a lubricant when fitting handlebars rubbers on bikes so that might work. It dries and sets up.
Good luck - you are a brave man
Mark
Old 06-19-2006, 04:55 PM
Thanks for the replies, appears that Energy Suspension Upper Control Arm bushings are not useable for the '95-'04 4WD Blazer.
According to Energy Suspension, "Uppers must reuse existing outer shells and all hardware;" "You burn the rubber out, clean the shell, and install the bushing."
The problem with this is that the existing outer shells have an integrated, serrated (sp?) washer at each end that must be removed. Of course, removal of the washer destroys the shell. Guess that is why the MOOG replacements come with the shell and integrated washers. Unfortunately, the MOOG's are rubber and not poly !
BlazerLT, the upper control arm bushings were shot (along with the upper ball joint and sway bar end links). So, while I'm in there, figured I'd be smart and replace with poly from Energy Suspension (along with new KYB shocks; and MOOG upper and lower ball joints)
Old 02-17-2008, 11:36 AM
ameelou72 ameelou72 is offline
Question Re: Upper Control Arm Bushings
this may sound stupid but I'm having a hard time locating the upper bushings in my 1997 4wd blazer any one help me please
Old 02-17-2008, 12:56 PM
tempfixit tempfixit is offline
This site should help you locate bushings:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 02-17-2008, 06:54 PM
old_master's Avatar
Advisor/Moderator
GM R series is full size 2WD and uses coil springs. All T series (4WD) use torsion bars, not springs. The location is essentially the same but repair procedures are totally different.
Old 02-17-2008, 09:10 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
thread is over a year and a half old. please check the thread dates before posting.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
